Ratdude's Main Rig V5.6
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Ratdude's Main Rig V5.6
    Originally posted by Hondaman
    Impressive. I only wish I had the time to put together such a great build. I was thinking about putting one of my 'Kabini' mini-ITX boards (2.05 GHz 4-core CPU) on a pizza box and plugging in my Radeon 7770 passive cooled video, for Folding@Home (then rig up some 120mm fans), but your rig looks much more well-rounded.
    (Mine would be CPU-poor and GPU-rich).
    It looks like you're gonna have a fantastic rig there.
    You're still running F@H? I ditched that 6+ years ago. Never got the linux version to run stably, and with all my workstations using fan curves, anything that creates extra heat (read: noise) without a good reason is banned. More power to ya...
    This is nothing... a rehash more or less of a prior build. I have a faster rig already anyway:
    https://www.badcaps.net/forum/showthread.php?t=64744
    This is likely going to be my wife's new system to replace her venerable dual opteron SLI monster (which will probably replace the dual-irwindale basement rig I'm posting from, although both systems are cool and run well )
    sigpic
    (Insert witty quote here)
    • Hondaman
      • Sep 2008
      • 1077
      No, I ditched Folding@Home years ago also (got 850,000 points or units or whatever, gave it up). Thought about getting one going again recently, just for fun.
      Last time, the CPU client (version 7) really heated up the VRMs, but with my 6770 video's passive fins, the version 7 GPU client didn't heat it up that much. I'll use the GPU client again, this time on my 7770 passive (AFAIK the fastest fully-passive video card ever made). I could also grab another cache-less SSD. For a "set it and forget it" system in my basement, hard drive throughput is not very important.
      EDIT: (Of course, getting wifi to work under Linux can be a nightmare!)
      ANOTHER EDIT: I just discovered the small "donut" spare tire has rotted inside the trunk (boot, rear end) of my 2002 Saturn. I really need to move quickly to replace it with a 14 or 15-inch proper tire before spending time on "leisure pursuits" like computers. I already replaced the "donut" tire on the 2001 Saturn when it rotted years ago, so that car is okay.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Now all I need are some SAS drives... As I don't think the one spare 147GB one I have leftover from V6 will cut it . Not seeing any deals on eBay... best offered on a lot of 6 but I doubt it will take. Some items I can strike bargains on (or snipe). HDDs don't seem to be one of them
        Well, the seller accepted my lowball offer... Got six 146GB 15K drives on order (some are fujitsu, some are seagate). I have a 7th as a spare... so I need at least 1 more to fill the array. Hmm... may have to do more hunting...
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Well, I've been working on it... and it's been a battle:
          I've had a few SAS drives die on me. One from the first batch of 6, and 2 from the third batch of 3. I ordered a 2nd batch of 2 which were fine, and my one spare also works.
          I also have a dead SAS cable... bay #3 is intermittently dead... though I had another bad HDD, nope, it's the cable or backplane. The cables are way too long, so I'm going there first.
          I did get a GPU for it... the monster Zotac 970 from the original V5. I tried to SLI V6, which failed, but part of that was moving the card to here.
          I did SLIC the bios (like the first one)... no brick. Whew.
          I have pics but it's a mess and it's late. It's running, albeit with the RAID 10 in a degraded state. I'll get it figured out.
          sigpic
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Another day, another setback. SAS cables came in yesterday, and I set it up tonight... and now I see no drives. The aren't even getting a spinup command...
            I'm pretty sure I ordered the correct cables...
            https://www.ebay.com/itm/1-5FT-SAS-t...72.m2749.l2649
            Odd that both are dead... it's not the missing sidebands as the old cables didn't have them either and yet most of my drives showed up there.
            Faulty batch of cables?
            sigpic
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              #26
              That eBay AD is ass-backwards.
              In the connection example picture he shows a reverse SAS cable.
              But in the text it's a forward SAS cable.
              So if it's not working probably it's the wrong type of cable...
              https://forums.unraid.net/topic/1106...rd-or-reverse/
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I was going to suggest that. Anytime you go from a miniSAS plug on a controller to SATA plugs either on cage or directly to HDD's, you want a 'forward' cable. If you go from a miniSAS plug on a cage/backplane to SATA connectors on a motherboard/controller, you want reverse.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  It said forward... for connecting 4 drives to 1 controller. I guess "mislabeled" counts as faulty... Anyway.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Fresh cables came in... they look like the same thing. And also do not work.
                    Link:
                    https://www.ebay.com/itm/Internal-Mi...72.m2749.l2649
                    I wonder if my backplane is FUBAR. I did find a jumper sitting in the bottom of the case... Ideas?
                    sigpic
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Does it support SAS? There are some versions that don't.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        The backplane? Yeah, I'm pretty sure... if not, the SAS cutout wouldn't be there, right? Oh wait... it did work with the first round of cables... so unless a jumper fell off, then I got bad cables twice. F*ck me...
                        Edit- as per one of my pics above, it's an SAS743TQ. So yes. Will see about getting a manual for it. Edit2- found and attached
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          No bueno. Seems I got shit cables twice in a row. Bullshit. Try try again... this time get cables with sidebands? Dunno if it's actually needed or not.
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            tried connecting them directly to the drive (will need adapters), bypassing the backplane? Two rounds of bad ones.....I don't think I've ever seen a bad SATA/SAS cable that wasn't physically damaged (cut, crimped, pinched).
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #34
                              Well they don't need to be bad, it might just be the wrong type of cables?
                              They do after all look identical to the first cables you bought...
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Not as advertised... the second ad was clear as what they were supposed to be... But that's what I'm thinking. "Bad" as in "not as ordered".
                                sigpic
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Ordered a third set of cables... and finally, she works!
                                  Yup, 4 faulty cables. May be the wrong direction... but I literally have no way to test. Not that it matters.
                                  I guess the cheap blue SAS cables on ebay are universally garbage
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Originally posted by diif
                                    Umm ok, 10 would be better you know. I suppose you do have your other machines for backup.
                                    I think the motherboard would reject that like a human rejects the heart of a baboon.
                                    This was from the original V5 thread... sure diff meant RAID 10 (which I ultimatly did use several revisions later)... but regarding Topcat's comment then on Windows 10, we're about to find out!
                                    My wife is just now getting to using it... and as preventative future proofing, I'm putting it on Windows 10 (since she is gaming with it).
                                    Direct install didn't want to see my RAID array... I'm trying upgrading the windows 7 install now to see if that works around the array detection issue (I remember the windows 7 install being fluky as well, ****ing adaptec).
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      So far it's been a fail thanks to the RAID array not showing up. It seems to see the card (I was able to obtain drivers signed for 10) but not the array as a valid drive. Odd???
                                      The upgrade crashed in a spectacular fashion... weird.
                                      I'll try reinstalling 7 enough to try the upgrade again. I have the genuine ticket backed up so hopefully I can work through it. If not, SM made LSI based UIO cards but they're $100 a pop on ebay, no BBU.
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        7 saw the array... must be a windows 10 issue.
                                        sigpic
                                        • ChaosLegionnaire
                                          HC Overclocker
                                          • Jul 2012
                                          • 3264
                                          • Singapore
                                          #40
                                          what flavour of win10 is it? it must be win10 pro or some enterprise version or such to get win10 to work with raid arrays. the home versions of win7 and 10 dont have the feature to work with raid arrays or such.
                                            ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 10:50 PM
                                            ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 11:05 AM
                                            ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                            This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 07:07 AM
