So, I had a dead-ish Asus GTX275. Since I want to match it with its identical brother for some retro SLI fun, I decided to give it a baking and see if that gets it working again.
Turns out the solid caps onboard were not appreciative of 220*C
Yeah, I should have been not-lazy and desoldered them first but I was lazy
There's only 9 in total on the board with four visibly failed. I'm working under the assumption that they'll all be sick.
3x marked
8mm x 12mm. Presumably +12v PCIe power input filters. I'm guessing 270uf and 16 volts.
Assuming that's correct, would these be suitable replacements?
https://au.element14.com/panasonic-e...16v/dp/2759055
and 6x marked (the four failed are in this bunch)
8mm x 10mm
I'm guessing these are Nichicon FP-Caps, 820uf and 2.5v, responsible for filtering the VRM output.
Replace with these?
https://au.element14.com/nichicon/rl...-5v/dp/2841880
Thanks guys, I appreciate the input.
3x marked
ECP11
Stylised "C"270
16V
Stylised "C"270
16V
FP
97Qd
8 2 1
2.5
97Qd
8 2 1
2.5
Replace with these?
