Killer Computer Cases Research
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
    Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
    The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
    Securing a good thermal interface between...
    10-07-2024, 04:35 AM
  • chaos-theory
    Asrock Fatality Killer Z97x boardview
    by chaos-theory
    I need the boardview for the Asrock fatality killer z97x
    It's my own motherboard and I really need to fix it, I need it for work, both my motherboards broke at almost the same time, and I don't have any backup to continue my work, if anyone can share the boadview, I will immensely be grateful!...
    03-14-2025, 05:18 PM
  • Nivla liu
    Board view for ASRock X370 Killer SLI/ac
    by Nivla liu
    Looking for the board view or schematic for the ASRock x370 Killer SLI/ac, Board died, and I want to see if I can spot the fault and see if it could be repaired,
    Thanks for looking, and if you have the file a big thanks.
    Nivla
    02-17-2025, 06:34 PM
  • kevin_allein
    CKV Short Killer
    by kevin_allein
    Hi, recently I found a lot of videos on YouTube regarding CKV Short Killer. All of those Videos seem to be from Asia (e.g. in Hindi). I could not find a single English Video. Translation on YouTube on those videos does not work well, so it is hard to understand details.
    Basically it seems to address the frequent problems of LCD panels, when CKV and CKVB lines have some short and the only fix is to cut those lines or use tape on the ribbon cable to the secondary scalar board of the panel.
    Does anyone have any experience with that ?
    02-07-2025, 07:03 AM
