ATI drivers on Fedora 10?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Anyone know how to do this? I've tried searching google for it and noting of any substance comes up.
    The motherboard is a Biostar A740G-M2+ with integrated video. The integrated video is an ATI Radeon 2100.
    Here are the issues:
    1. Install CD won't boot. It wont make it to the graphical installer, and it won't go to the text mode install either. Hitting esc on the countdown and typing "linux text" doesn't work.
    2. After using an Nvidia card to get the stupid thing installed, there is no xorg.conf that I can edit to change it to use the vesa driver so I might be able to boot with the integrated video, so I might attempt to install the proprietary ATI driver! WTF??!!
    Fortunately the board was cheap enough, and so was the Sempron I'm using with it. I got it for the sole purpose of evaluating the AMD / ATI platform on various operating systems. So far, it's not looking good under Linux. The Windows 7 Beta works ok though.
    Any ideas?
    A man convinced against his will is of the same opinion still.
  • Wizard
    • Mar 2008
    • 2296
    Re: ATI drivers on Fedora 10?
    1. Biostar is not best of board engineering in regard and their bios. I see bit of issues with others esp on linux not just this board brand.
    2. See if the bios is up to date.
    Otherwise, pick one level up like 790G instead of 740 based on decent board like Asus etc.
    Cheers, Wizard
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      I do not consider Asus to be decent.
      Do you have any proof that Biostar's bios is flawed in some way? They've always worked well for me. In fact, it's always Asus that has had strange issues for me.
      Oh well, I guess it's back to Nvidia chipsets. Never had a problem with them on Biostar boards under Linux.
      • jpdoe
        • May 2007
        • 237
        That kind of problems are usually solved using kernel boot options.
        Make a google search with the terms
        kernel boot options
        if you're not familiar with them
        But since there's a huge amount of them, first take a look at these pages
        https://bugzilla.redhat.com/show_bug.cgi?id=nomodeset
        https://bugzilla.redhat.com/show_bug.cgi?id=487268
        They seem to say the
        nomodeset
        boot option is the way to go
        • Wizard
          • Mar 2008
          • 2296
          Hmm.
          Which boards are *considered* best? Intel, Asus, Foxconn, so on?
          Cheers, Wizard
          • acstech
            GrumpyModerator
            • Jul 2007
            • 1432
            Ok it worked under Ubuntu 9 (prerelease). Haven't tried messing with things, but it's sitting on the Ubuntu desktop and working properly there.
            Which boards are *considered* the best? Depends on who you ask. If you ask the Asus shills on the internet, well, you know what answer they'll give. As for me, I've had so many bad experiences with Asus that I won't touch them with a 29 1/2 foot pole. Shall I explain them?
            Here's my thoughts on boards:
            1. Asus: Junk. Possible inadequate cooling (M2N-E), insufficient bios options (C90P laptop, M2N), faulty chipset fans (several boards including A8N-E), faulty BIOS (C90P laptop), inadequate fan control (all boards I've worked with), instability (A8N-E), poor overclocking on less than top end boards. overpriced. I have more.
            2. Gigabyte: Generally ok, with the exception of one DOA micro-ATX Nvidia 7025 based board. Inadequate fan control, otherwise ok.
            3. Intel desktop boards: Generally ok, stable at stock clock speeds. Possibly overpriced depending on which one you look at. Not AMD compatible.
            4. Biostar: Generally ok, low end non T-series boards have slightly limited fan control options and just "ok" overclocking. Most stable boards I've worked with. Fan control on T-series boards is without equal. All boards have decent caps on CPU VRM, with T-series having solid caps on VRM output. T-power have solid caps everywhere. One drawback is OST caps on non-critical positions on T-series boards. Doesn't limit overclocking or cause a problem in reasonably cooled computers though.
            Dont' know about Foxconn. Always considered them a lowest bidder budget brand. Maybe they're worth a look. But the Biostar has been working well for me for the last 4 or so years in the computers I sell. Haven't had to replace one yet. Can't say that about Asus.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              How about a 29 3/4 foot pole?
              Mann-Made Global Warming.
              - Dr Seuss
              • acstech
                GrumpyModerator
                • Jul 2007
                • 1432
                Typo. It was supposed to be 39 1/2 foot pole.
                • NxB
                  • Feb 2009
                  • 1595
                  Foxconn had a different ACPI table for linux, one which would cause serious problems. Cross them off the list for linux or anything. MSI and ECS have been good for me. I've lost some boards from every manufacturer so there is no *BEST*.
                  Linux stopped "using" the xorg.conf for a while now. Graphics have been configured by X some other way. My xorg.conf has like nothing in it. Linux mint works for me, as do ubuntu flavors, recent releases completely out of the box. I've had trouble with downloading and installing them manually. Package manager has always worked for me, better than windows drivers even (no smartgart). I wish I could say the same for sound.
                  • japlytic
                    DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                    by japlytic
                    In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                    Tried (only with keyboard/mouse connected):
                    • BIOS + database update
                    • Using latest Windows 11 image built with official image creation tool
                    • Previous setup version for Windows 11 installer
                    • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                    • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                    • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                    06-19-2025, 04:59 PM
                  • ivtec
                    install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                    by ivtec
                    Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                    01-17-2025, 12:54 PM
                  • hpw19b
                    Default Lenovo LEGION Y530 (NS-B961 Rev 1.0) unavailable to install nvidia drivers
                    by hpw19b
                    I have recently unlocked supervisor password and flashed bios, now if i look at bios it does not show device name and device S/N. Also lenovo vantage app does not seem to work (i guess its releated to device name and serial)
                    Now the nvidia gtx 1060 driver does not want to install. Intel UHD 630 driver installs fine.
                    Ive tried: format
                    Wiindows update to latest version
                    DDU (display driver uninstaller) in safe mode and all the other things i found in google.
                    Device manager: This device is not working properly because Windows cannot load the drivers required...
                    04-14-2021, 11:52 PM
                  • 24gsm
                    MacBook Pro A1708 install macos fail
                    by 24gsm
                    hi to all
                    i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                    after enter to recovery and format hdd 1to .
                    after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                    can help please
                    Serial Number: FVFXP0U0HV2J
                    Config Code: HV2J
                    Find My Mac: OFF
                    04-16-2025, 03:57 AM
                  • ademturk
                    optiplex 7010 micro plus
                    by ademturk
                    i think i really stuffed it i dont have backup of original bios iam trying to connect this ch341a for a few weeks now just yesterday i managed to find my problem all this time the green board between the wire and dongle was on the wrong way. ive downloaded the BIOS_IMG_rcv file renamed rcv to bin but the programmer says its too big also tech friend had a look at it and said it was bios was security protected. ive used imsprog and flashrom from linux and from windows i have tried neoprogrammer asprogrammer and original ch341a programmer. also the main reason i had trouble connecting was the...
                    06-23-2025, 04:21 PM
