The 2018 Operating System thread
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
Re: The 2018 Operating System thread
I said: "I initially thought that when SMT came along. But, eventually realized it was just a new set of tools and skills."
Not exactly.
New stuff tends to be built like shit and not really made to be serviced. It's really mostly debugging software these days. Whenever there is a hardware problem, it's just easier (and often cheaper) to replace things rather than try to fix things on the hardware level.
So your new tools and skill set are pretty much limited to "rebooting" and/or "try powering it off and on again".
For example:- hot air irons instead of traditional irons for thru-hole
- component handling and PnP tools for really tiny parts (I don't need a stereoscope to do thru-hole!)
- layout tools that more readily supported higher component/signal densities, components on both sides of boards
- finer lead pitches and tighter DRC's
- oddball packaging options (e.g., chip-on-chip)
You can still repair boards -- you just need different tools to manipulate the components.
[Assuming you can sort out what is happening in the circuit without documentation AND that the components involved are COTS devices]
The reason it isnt economical to repair boards is that the costs of labor have continued to climb whereas production costs have continued to fall. If you are willing to work for le$$ -- or, pay more for new products -- then the calculus changes.
I.e., most folks here place a low enough value on their "uncommitted" personal time that it "makes sense" (economically) to repair something instead of replacing. Their attitudes might change if they didn't have "uncommitted time" (i.e., were working long hours that ate into their "free" time -- easier to BUY a new whatever and spend the free time you have doing something you need or enjoy, more!)Comment
Windows 10. I've always been a fan of Windows 7, but 8 didn't quite fit the bill. I got Windows 10 when I upgraded my computer, because some of the drivers didn't work on Windows 7.
Now I like it so much that I don't plan to change it anymore.Comment
And Vista is a bad one, it also takes forever to get to the login screen, but on faster PCs, should login at an OK rate but can randomly hang (sit in one place for a while, possibly with zero HDD activity). Vista is even more likely to have ton of HDD activity even after login.....
7 on some PCs may randomly hang on login, (take a real long time, with possibly zero HDD activity) but shouldn't be forced to hard reboot.....Last edited by RJARRRPCGP; 01-27-2018, 10:53 AM.ASRock B550 PG Velocita
Arc A770 16 GB
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...-
Channel: Schematics and Boardviews
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by FALKLANHowdy everyone! I hope all is well where ever you are!
I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
I am uncertain how to convert this line into a switched 12v output line for the LED pods.... -
NVIDIA GeForce RTX 2080 Ti Schematic & Board View
The GeForce RTX 2080 Ti is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2018. Built on the 12 nm process, and based on the TU102 graphics processor, in its TU102-300A-K1-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2080 Ti. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU102 graphics processor is a large chip with a die area of 754...-
10-02-2024, 08:01 AM -
NVIDIA GeForce RTX 2080 Schematic & Board View
The GeForce RTX 2080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2018. Built on the 12 nm process, and based on the TU104 graphics processor, in its TU104-400A-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU104 graphics processor is a large chip with a die area of 545 mm² and 13,600...-
10-02-2024, 07:57 AM -
- Loading...
