Intel server board, REALLY frustrating BIOS issues!
  • Maxxarcade
    • Jul 2006
    • 973
    Long time no post guys! But I remembered to drop by here when this system stumped me today.
    I'm working on an Intel S5000XVN for a customer. When I press F2 to enter the BIOS, it says "Entering Setup..." on the screen, but then proceeds to boot the OS, no matter what I do.
    If I disconnect all drives from the SATA ports, it will go into the BIOS on its own.
    It also changes the boot priority on its own. I'm not sure how to explain it. But if I connect only the DVD drive, I can boot from that. But after connecting the SSD with the OS on it, it still only boots from the DVD drive. Taking the disc out will cause it to attempt PXE boot, and it won't go further even though the SSD is connected. The same happens if I use just the SSD. It seems to kill off the DVD drive until I disconnect the SSD.
    And since the BIOS won't load with any drives connected, I can't manually set the boot order. And with no drives connected and BIOS loaded, there are no devices to set as boot priorities. Know what I mean? I'm stumped at this point.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Intel server board, REALLY frustrating BIOS issues!
    I'd check the CMOS battery and install this if you haven't already. https://downloadcenter.intel.com/dow...ackage-for-DOS
    • Maxxarcade
      • Jul 2006
      • 973
      The battery tested good at 3.14 volts. I'm hesitant to mess with the BIOS until the owner backs up their files. Though it appears to already have that version installed.
      I'll have the system back in my shop next weekend to do a video card upgrade, and I'll look at it some more then.
      • kenkaniff
        HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
        by kenkaniff
        Product Name: HP Pro x360 Fortis 11-inch G9
        System BIOS: U94 Ver.01.08.00 10/06/2023
        Serial Number: 5CG31946F5
        SKU Number: 85W05EC#AK8
        Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
        This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
        I needed to remove bios password...
        10-01-2025, 04:32 AM
      • q2v5
        Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
        by q2v5
        Lenovo T480s
        Model 20L8-S3TE00
        Board ET481-U10
        Chip MX25L12873F
        Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
        2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
        The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
        08-15-2024, 10:40 PM
      • Max029
        Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
        by Max029
        I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
        I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
        TY,
        08-18-2024, 08:28 PM
      • futadmytro
        Asus g713qm-es94 stuck on boot bios problem
        by futadmytro
        sn^M4NRKD02753616E
        MB- g533-6050a3250201-MB-A03
        Stuck on boot after ROG logo, did not enter to bios
        In flash bios , laprop boot but have video issue
        orig bios...
        06-25-2025, 08:07 AM
        by Vesko356
        08-11-2023, 03:27 AM
