Cheap Source for Racks?
  • diif
    replied
    Re: Cheap Source for Racks?
    That switch supports link aggregation, your unamanaged switches do not.
  • ratdude747
    replied
    Crap. try 2's real link:
    http://www.ebay.com/itm/292223781061...N101.S1.R1.TR4
  • ratdude747
    replied
    Originally posted by diif
    Good enough for what ? Server to switch is ok as we know.
    Switch to switch they both need to support 802.1AX or 802.3ad as it was called.
    So I couldn't put a managed 8 port switch between the two unmanaged 24 port switches? The managed switch would have two 4 port aggregated links. Same idea as bonding/teaming on a server?
  • diif
    replied
  • ratdude747
    replied
    No, for link aggregation on switches to work all switches must support it.
    My 3com switches are cool with my server and topcat's stuff (same model switch) aggregating links. Good enough?
  • diif
    replied
    Good point... apparently I'd need a middleman managed switch of some sort that was managed to setup the link aggregation between switches. I did see managed 8 port switches out there, for how cheap I'd have to see.
    Doh!
    Or I just run 8 links or something direct to the office (leaving 10 spare links for other rooms, wifi router, and additional access points) and keep the second switch as a spare. Damn, my wooden workstation cart's rear was perfectly spaced for a 19" rackmount switch too.
    edit- here we go: http://www.ebay.com/itm/D-Link-DGS-D...8AAOSwIxxZn367
    I'll RTFM first, but I bet I could set that up to do two 4gbs trunked lines... edit2: Nope, not actually a managed switch. Good thing I didn't buy.
  • ratdude747
    replied
    ^Yup, option 2. Option 1 doesn't work because of the internal layout of my routers.
  • ratdude747
    replied
    Screw it.
    I'm thinking of a compromise, for now:
    Option 1: Configure one of my two spare gigabit N routers (OpenWRT) as a managed switch and AP combo and use that as a 2gbs trunking adapter.
    Option 2: 5 links: two for each of the two workstations, and the 5th to the switch for slower devices (laptop docks, laser AIO, other workstations, etc.).
    I'm leaning towards option 2.
  • ratdude747
    replied
    Try 2:
    Put in an offer. Wife says I spent too much money today.
    Other suggestions are welcome.
    Edit- counteroffered... I want to sleep on it.
  • ratdude747
    replied
    How are you planning to connect the two switches ?
    Doh!
  • diif
    replied
  • ratdude747
    replied
    Saw this:
    http://www.ebay.com/itm/Cisco-SGE201...4AAOSw7pNZnYVX
    But nah, probably unrepairable junk?
    Reason I ask is I just scored some dirt cheap quad port gigabit cards and thinking that 24 ports isn't going to cut it. Or not and I get a 16 port switch for the office and give it 4 links (So I can quad team my workstation and dual team my wife's workstation, but neither of us will need all the bandwidth at the same time?
    Yeah, screw a 48 port switch, I found another 3com 32 port switch (identical to the existing one) for peanuts:
    http://www.ebay.com/itm/332337362678
    Even cheaper than the first! Also cheaper than any 16 port switch I could find.
    So I'm thinking six links between the two (one full wall plate) to start would be good. Six links to the server (will have 2 on board +4 via card) too.
    Yay I have to order more patch cables... Oh well, the costs of doing things right.
  • ratdude747
    replied
    Saw this:
  • Curious.George
    replied
    ^I've heard that elsewhere, and I'm using CAT5e. I'll be doing gigabit, but 5e should handle it.
    The devices that will most commonly see/need fat pipes are all colocated in my office or server closet. So, cabling and dedicated 24p switches can handle those needs without penalizing the rest of the house (I've run ~6000 ft of CAT5e, here). The balance of the loads are things like "appliances", laptops wanting an outbound connection, TV's, media tanks, etc. All of which are inherently lower bandwidth consumers. Silly to run Gb to a VoIP handset!
    As for sealing fire-stops, IIRC they make a product for sealing such holes (not expanding foam for windows!)
    I use "3M Fire Barrier Sealant CP 25WB+". It is colored red (perhaps a Code requirement to make it easier for inspectors to verify that it isn't "just caulk"?) so it makes it easy to see which "penetrations" have been treated, or not.
  • ratdude747
    replied
  • Curious.George
    replied
    I went ahead and jumped... on a patch panel. Found a 32 point keystone panel for $16 shipped. I'm going with keystones because I don't want a bad jack to kill a whole panel. Plus I can choose Cat5(e) or Cat6.
    As for the hookups, I'm thinking floor plates (keystone) would be the way to go. The house I'm lookign at (and put an offer on) has a crawspace on one level (trilevel house) and a basement garage on the other. Easier than walls and attics?
    Also, Should I do Cat5e or Cat6?
    CAT6 is a bit harder to handle, and a bit fussier about how it is handled. Consider, carefully, what you are likely to have on each "drop" and the reasonable bandwidth you might need (yeah, you may want to transfer gobs of data from a file server to another file server, but will they tend to be located at opposite ends of the house?)
    I installed a 96 port custom switch in a closet. Short patch cords connect it to a pair of 48 port panels in the side walls. Cables run through the walls, from there, to the individual drops around the house.
    The switch is PoE & 1588 enabled with a large 48V DC "battery" kept up by a 48V power supply (PoE distributes 48V DC to the PD's so no conversion losses, there). As expected, most of the devices are PoE powered. So, everything is "battery backed" in the event of an outage (instead of needing a UPS at each device). The switch can be commanded to shed individual PD loads to make better use of available battery capacity.
    I opted to run CAT5e instead of CAT6 because it is easier to handle and a bit more forgiving of installation abuses. As each drop is essentially a single device (i.e., the only "combined traffic" happens inside the switch, not over a drop to another switch), 100Mb is more than adequate to deliver live video, etc. to a node.
    Be sure you carefully examine how you intend to run the cable as there are Code restrictions that dictate when Plenum rating is required vs. Riser. You may also be required to seal around every hole that you drill through a fire-stop along the way. I.e., think before you invest a lot of time, money and effort!
  • Curious.George
    replied
    [Admittedly belated reply...]
    Question: I'm going to be (hopfully) moving into a house sometime in the next handful of months, and I'd like to have a rack for my blade server(s) that will be doing NAS and the like along with a 24 port gig switch (they're like $25-$40 shipped used on ebay right now )
    However, the only used ones I've seen are 3 hours away at Purdue Surplus, and they're massive full height ones (for $50-$150 a pop usually), all OEM.
    New ones at Fry's and online seem a bit cheaply made for the asking price. $175 for two metal poles and an anchoring plate? No thanks.
    Look at local universities, school systems, etc. in your "neighborhood". Most have surplus equipment auctions pretty regularly. E.g., a full size, enclosed (front and back doors, etc.) rack, here, will run you $10. And, they will be thrilled that you took it off their hands!
    I don't need (or want) that big of a rack... 12U would work but 20+ would probably be safer, especially if I ever add anything else. Having a shelf on top would be nice as that would allow me to set my AP and (if I stay with cable) modem on top, not buried inside the rack.
    Short racks are scarcer. I had three (custom) ~15U racks (with weight-bearing tops!) that housed my Cipher 990's years ago. Foolishly discarded the racks with the transports. If I'd kept them, adding a fourth would have made an excellent "pedestal" base for my bed (with lots of accessible storage beneath!)
    Consider the location of your AP(s) carefully. You want to ensure adequate coverage around your site. I located a pair of them on the ceilings of two closets at opposite sides of the (single floor) house. They are PoE powered so no hassles with wall-warts, AC mains, etc.
    It also would need to be deep (or have an open back); I have a long 2U IBM X3650 server to put in. She's a tad heavy though (40lbs?) so it would also need to be sturdy
    I have heard of people using generic shelving for rackmount gear; I'd like to avoid that as I'm afraid of a cable getting snagged and things flying off the shelf.
    I kept my 2U servers under my worktables, centered with my chair. This allowed them to act as convenient foot-rests while seated. I've discarded all but one 1U server which sits under an LJ4M+ (as it is strong enough to support the weight of that printer). It will be exiting the building in the next week as I've moved to smaller boxes with "friendlier" form factors.
    [Though I still have a behemoth blade server (14 x dual, 3GHz quad-core Xeons, 2 x 72GB drives per blade) that I need to decommission]
    Also, consider buying a 1U console and N-port KVM for (each) rack -- if you intend to "locally" administer the systems housed therein. I used a pair of these until recently:
    <http://www.disctech.com/Dell-KMM-PF033-Rack-Mounted-Console-15-LCD-15FP-1U>
    I now remotely administer everything (TELNET/SSH) -- while keeping a small, SEVEN inch LCD as a "portable console" for the worst case of machines that refuse ping(1)s.
    Or, come to your senses and realize that smaller can be better!
    E.g., my "file server" is now implemented as a set of six 1.6GHz Atom USFF machines with external (USB) drives, managed by some custom software and a centralized database (so I can query the contents of the "file store" without having any of those disks actually spinning -- so I can see what I have, where it is located, and how it can be accessed). The USFF's draw about 10W -- and only when running. Considerably less than the JBOD shelf's of 15K SCA drives I used to run!
    (of course, I use a file server as an archive, not as a high performance service!)
  • ratdude747
    replied
    Rack reconfiguration coming:
    https://www.badcaps.net/forum/showth...558#post761558
    Good thing I didn't drill or cut anything yet. Dell 1U won't be in this either, as I should be able to make it's HDDs run in this (SATA on board ,not RAID card) until I get real drives in it.
  • ratdude747
    replied
    ^ Stupid question. Cat6, Cat 6 for buildings (solid) at least at Lowe's was about the same price... $75 vs $68 for 500'. I won't buy it there, but for the price, I might as well future proof. No, I am not touching copper cladded crap.
  • ratdude747
    replied
    Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
    by sam_sam_sam
    Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
    I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
    09-13-2024, 06:47 AM
  • Spork Schivago
    Identification of two round holes on top of rack.
    by Spork Schivago
    Hello!
    I've searched the internet, skimmed through a lot of HPE PDFs, all searching for the answer to a simple question. On the top of my HPE H6J77A Advanced Series rack (36U), there are two round holes on the front top of the rack. What are those holes for?
    Here is a picture of the holes that I'm talking about. I know what the square on the back is for.
    I originally thought fans, but no, the fan kit is for the middle of the top of the rack. Then I thought maybe duct work for cooling, but that doesn't make sense with both being on the top there. I looked...
    10-27-2018, 04:50 PM
  • slybunda
    Capacitor shelf life or expiry date?
    by slybunda
    do capacitors have a limited life even if just kept in a box in storage?
    11-20-2023, 02:23 AM
  • MeanStreets
    Ibanez Delay Rack Re-Cap
    by MeanStreets
    Hoping to get some insight on how best to go about overhauling this old Ibanez delay. Its from 1983 so it celebrates its 40th birthday this year, the unit still functions however i heard a high pitch oscillating whine from it a few weeks ago and decided to strip the chassis and have a look.
    It looks like the 25v and 16v caps are leaking, there have been a few replacement caps in its lifetime as it has some bi-polar caps installed that differ from the polarized ones in the unit.
    My plan was to swap out all of the electrolytic capacitors,...
    05-11-2023, 03:32 PM
  • 5mall5nail5
    Help identifying connector for ASUS 4090 Strix RGB LED connector
    by 5mall5nail5
    Hi All -
    I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
    Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
    05-04-2025, 07:47 AM
