Can I Delete the PerfLogs Folder?
  • ivtec
    • Dec 2008
    • 1967
    I guys can i delete PerfLogs Folder?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Can I Delete the PerfLogs Folder?
    Any reason you'd want to ?
    • ivtec
      • Dec 2008
      • 1967
      the reason is that i kept uninstalling Kodi clean, and the only way i could uninstall it clean was to delete the perfectlogs that had the name Kodi,other wise i kept uninstalling it and all files addons and so on were there upon install,i scratched my head figuring it out,
      • diif
        • Feb 2014
        • 6978
        • England
        I didn't know Kodi kept its config files there, something new learned.
        I think you've answered your own question. I don't think there is any need to delete the whole folder although it shouldn't do any harm if you do. Just deleting the required files within is all that is needed.
        • R_J
          • Jun 2012
          • 9559
          you need to delete the c:\Users\[your user name]AppData\Roaming\Kodi directory, thats where the adons and userdata are stored
          not the perflogs dir
          (you will need to check "show hidden files,folder,or drives under Folder Options - View
          • ivtec
            • Dec 2008
            • 1967
            Thanks guys,as i said on my previous post by cleaning perfectlogs that had the name Kodi
            did the trick.thanks
            • R_J
              • Jun 2012
              • 9559
              The perflogs folder is populated by generating a system health report, it is not created by kodi
              when uninstalling kodi there is a small box to check to grant permission to delete the profile directory, if you do not check this box the uninstall will leave all your settings, addons etc.
              • EpicFix
                Where is the "Desktop" folder located in Windows 11?
                by EpicFix
                At the risk of sounding like a total noob I'm asking If anyone can help me locate the "Desktop" folder on Windows 11. I am trying to make a backup of all the user data from an SSD (mounted externally) that has Windows 11 installed. I was able to do this before up to Windows 10 by navigating to the User folder --> Username and there I would see the individual folders, Documents, Downloads etc. Attached is a screenshot of the folders I do see within the Users / Username folder. Any help locating the desktop folder will be greatly appreciated. Thanks in advance to the community. ...
                07-12-2025, 07:14 AM
              • zioricci
                Folder Is empty
                by zioricci
                My Toshiba laptop stopped at the Toshiba logo when starting up, I flashed the bios and fixed it. Fortunately I had also backed up the data folder on an HP laptop with which in the meantime I reinstalled Windows 10 on the Toshiba hard drive using it as an external drive with which I am able to start the Toshiba after the problems solved.
                The real problem now is when I copy and paste the data folder from the HP back to the Toshiba hard drive, again using it as an external drive on the HP. In fact, when I put the disk back in the Toshiba, it tells me that The folder is empty but in...
                04-05-2023, 01:51 AM
                Copy DMI info easily with Hex editing software and Macro script
                by SMDFlea
                Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                02-28-2023, 02:14 PM
              • dqtech
                Macbook Air 13' Mid 2013 Question Mark Folder
                by dqtech
                macbook air mid 2013 A1466 problem with question mark folder.....when i took out the ssd it take around 40-50second to show folder after chime sound...but when i put the ssd back, took about 4-5minutes to show folder....what could be the problem?
                08-21-2022, 09:37 PM
              • alfredposadas09
                820-00928-a a1707 blinking folder
                by alfredposadas09
                hello can someone give me a guide on how to fix this blinking folder? i try to use external usb to reinstall mac os but i can't see the internal drive, what ssd voltages do i need to measure? pls help...
                05-21-2025, 07:58 AM
