help me guyz to update my bios.
  • justineneal25
    • Dec 2008
    i must update my bios because i bought a new processor,i dont know how to update it i have no floppy drive so i will use my flash drive plzzz help me.
  • bgavin
    • Jan 2007
    • 1355
    Re: help me guyz to update my bios.
    Many BIOS are updated through Win Flash. Your new processor will most likely boot up your system so you can flash it through Windows.
    An alternative is using a USB floppy drive.
    The manufacturers have removed floppies so they can save a dime, but this is seriously stupid. If you support computer systems for a living, you should already have a USB floppy (and USB cdrom).
    You can build a DOS bootable flash disk, but this is more diddling around. Buy or borrow a USB floppy drive. Painless.. cheap.. easy.
    • Wizard
      • Mar 2008
      • 2296
      or lug in ATA or SATA you have spare around around that simply boots to DOS or clean install of XP with flash utility and do the flash.
      • abhorsen
        Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
        by abhorsen
        Hey guys,
        Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
        Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
        Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
        07-06-2023, 10:22 AM
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
      • akwky
        by akwky
        Hi!
        04-14-2025, 01:56 PM
      • TyMercer
        Can I flash a working BIOS from one computer to another of the same make, model, etc?
        by TyMercer
        Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
        11-13-2025, 09:39 PM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
