How laptop charging works
  • Jane
    • Aug 2010
    • 189
    If I plug in a charger, what voltage should I measure coming to battery from charger?100% of the output voltage of the charger?Or less?
    Is voltage from the charger coming through any charger controller on mainboard?
    If I follow this procedure:
    I Remove battery
    Connect a charger
    Measure voltage on the connector and there is voltage( for a short time),so the path charger --> battery is OK
    Connect the battery
    Yet, no charging even though there is a voltage on the battery connector( but not sure if it is coming from the battery or from the charger)
    Does it mean the charging controller is faulty? or software problem?
    ANd what is a function of the charging controller on the mainboard?
    Thank you for explanation
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: How laptop charging works
    usually laptops have their own internal charging circuit to shield the possibility of a bad external charger. The external brick is merely a step down power supply.
    These things are probably easiest to test with another battery as it won't charge a questionable battery. One issue is that the charger will not turn on if it deems the battery is "explosion prone". How many volts is the battery currently when not connected to the charger (though this is not the only criterion for charging)? Does the voltage shoot up to the nominal voltage printed on the battery when connected to the charger?
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Thomasraud
      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
      by Thomasraud
      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
      QUOTED
      -It works on charger (without battery connected-only charger)
      -It works on battery (without charger connected-only battery)
      -& it also works when plugged in battery & charger, but it's not charging the battery
      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
      and..
      QUOTE
      The IC cannot maintain the input current level
      06-28-2022, 06:47 PM
      Bauer tool battery pack charging with a HERCULES charger modification
      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
      05-06-2023, 12:17 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
