As I am considering buying one, I am trying to find a smartwatch phone which supports data tethering via Wi-Fi and/or Bluetooth (so you can browse the web on a tablet while wearing your smartwatch phone while it is connected to the cellular network), and I cannot seem to find tethering apps for wearable devices incorporating cellular data access.
Tethering for smartwatch phones
Re: Tethering for smartwatch phones
The capability has existed for maybe 10-15+ years in phones, either through Bluetooth Dial-Up Networking (commonly found in Nokia 2G and later phones) or through Wi-Fi hotspot functionality (aka Mifi, found on most, if not all Android phones).
I did see a Chinese smartwatch recently that has a claimed 4G LTE modem *and* Wi-Fi hotspot capability (basically Mifi), which would allow the use of a notebook, tablet, WiFi-enabled phone anywhere where there is 4G coverage. However, that watch may be an informal Shanzhai-developed unit that is not formally approved by telecom regulatory authorities of any country (e.g. FCC).
If you're using almost any stock Linux distro on the client device, there's no need for any tethering app - the capability is included in NetworkManager, and it just works. In addition, most MiFi hotspot devices with USB charging and wired USB networking also work seamlessly under Linux. The Qualcomm-based Wi-Pod that I'm using to access 4G LTE services right now is one such, and comes with a built-in battery that allows a full day's operation without recharging the battery, either with USB networking or MiFi. As an aside, the service provider that I'm using, Reliance Jio in India, has one of the lowest announced rates for 4G wireless data in the world - about 15cents daily, though it's capped at 1GB for 21 hours, and no limit between 2 AM and 5 AM daily. If you exceed the cap, the speed falls back to 2G speeds, with no further cap or charge. I get anywhere between 3 Mbps and 30 Mbps on the 4G link, depending on the time of the day and network congestion.
In principle, I could just pop the unit into my pocket and use my notebook anywhere in India where there is 4G LTE coverage (about 100% in the bigger cities, and maybe 40% of the boonies).Comment
by chinhang899Hey everyone!
My KORG iS50 has a volume issue where the internal speakers are only acceptable above ~50% on the master slider. What's worse is that the headphone (phones out) and line outputs are extremely quiet, even at max volume. Both left and right channels are equally affected.
Here's what I've checked:
Voltages: Vcc to DAC section measures ~5V, MUSB (mute pin on the DAC) measures ~4.xxv, and the 2 op-amps show ~9V
Master Volume Slider: Resistance ranges from single-digit Ω to ~11kΩ (seems functional).
Visual Inspection: Capacitors on the main/speaker...3 Photos-
by DreigasHello,
About a year ago, I was struggling to find schematics whenever I needed them. As a programmer, I saw an opportunity and wrote a few scripts to automatically gather a large database of them. Today, I've decided to share it with everyone, because good things should be accessible to all.
What's included? Over 14,000 laptop schematics, as well as some BIOS files, and about 1,000 phone schematics.
Everything is compressed in a RAR format and is over 140 GB. (Since it's such a large file, your browser might show a warning.)
I plan to host the...-
Channel: Schematics and Boardviews
08-20-2025, 09:58 AM -
by datsnowHi!
I have this Huawei Smartwatch, model W1 or Classic (have seen both names).
The smartwatch works, but only when it's charging. It charges, but it gets very very hot to the touch.
If I unplug it from the charger, the smartwatch will endlessy reboot until it has no battery left. The battery drains very fast.
Replaced the battery with a brand new one, from Huawei, but I still have the same problem.
Upon disassembling the smartwatch, I identified two missings components on the PCB. This 2 components, are the one's that I circle around...-
by Boxinohi i have a vodophone mifi Model no MT28T its stuck on logo. can any one help me with the firmware and the flashing tool box or solution on how i can fix the problem. your positive response will be apprecitaed.
by wetpretzel2Does anyone have a board view or schematic for this model? Got a case of iPad not working after traveling abroad. need a board view to know what's getting hot, or warmer than everything else.. TIA
08-08-2024, 11:54 PM -
- Loading...
