Recommendations for a good POST card reader.
  • mariushm
    • May 2011
    • 3799
    Re: Recommendations for a good POST card reader.
    There's only one AGP slot per CPU. It's a point-to-point link, between card and processor, unlike PCI which is a shared bus.
    I guess it's possible (but highly unlikely) to have 2 agp slots on dual cpu systems.
    PCI-X was used for SCSI adapters and for dual/quad gigabit network cards (in servers)
    Regular PCI runs at 33.33 Mhz and it's 32 bit wide so ALL cards plugged in the PCI bus share the bandwidth which is a maximum of 133 MB/s
    So you can imagine a single PCI gigabit network card, which can reach up to 125 MB/s, would almost saturate the whole bus. You still had onboard audio connected to the pci bus, some motherboards had onboard firewire, some had additional usb and sata controllers connected to the same PCI bus.
    PCI-X with 64bit wide and 66 Mhz allowed for up to 533 MB/s of bandwidth, which made it possible to have dual and quad gigabit network cards on servers.
    Then we had pci-e which is point to point connection, not a shared bus... sort of like usb but not quite.
    * and a bit off topic, but basically AGP was heavily based on PCI. It "talks" like PCI but it's simplified in the sense that there's only one device per bus, there's fixed packet sizes instead of variable, it runs at 66 Mhz instead of 33 Mhz and has some additional stuff pci didn't have. If you're really curious you can read the Wikipedia page for agp : https://en.wikipedia.org/wiki/Accelerated_Graphics_Port
    and maybe you want to check the PCI page as well : https://en.wikipedia.org/wiki/Conventional_PCI
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      Originally posted by diif
      It wasn't a TPM you recovered a password from Spork. Its usually fitted to the more business class laptops to ensure data stays encrypted.
      Okay. I want to say it was an old 486 IBM ThinkPad (with the red button for a mouse). I remember soldering some really simple device and I connected it to the laptop somehow. I had to solder wires, if I remember correctly, directly to the board. I found the device. There's a serial adapter, and that's how I'd recover the password. I'd hook it to another machine and it'd either just pop right up or I'd run some special program. It has three wires that get soldered to the motherboard. It's got two resistors and two zener diodes. One of the wires has tape around it and I can see where I wrote SDA. The other one must have had the tape ripped off but would have said SCL and the third wire would have said GND.
      The password was one of three. They had a BIOS password, a startup password and a hard drive password. I was able to recover the one using this device, reset the other using some jumper on the motherboard or removing the CMOS battery, but the hard drive password I could never get. The password this device recovered was a swear word, like ass. The guy who brought me the PC said his friend was drunk and set them, I don't know if it's true or not.
      I tried making a circuit board on a breadboard that would kill the power to the hard drive, that I could control via my computer's serial or parallel cable. I never figured out how to do it. I wrote a program that would try and brute force the hard drive password, using IOCTLS or something along those lines (I don't remember, it was a long time ago). After three attempts, the hard drive had to cycle power to try again. I tried guessing all the swear words I could think of, but couldn't guess it.
      I just found the schematics: http://www.normsweb.com/tektips/thinkpad.shtml
      It was the Supervisor password that I recovered, and from looking at the site, it looks like it was stored on an Atmel 8-pin DIL (24RF08). I don't know why I thought it was stored in the TPM. Thanks for clearing up my rememory. I think things like this help my brain. A lot of times, my memories get mixed up. I'll remember two separate memories as one and intertwine them sometimes.
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • Spork Schivago
        • Mar 2012
        • 4734
        That PCI-X can be 32-bit as well though, right? Does that mean I can use it as 32-bit or 64-bit, or when it's designed, it was designed as either being 32-bit or 64-bit? Thanks for sharing this. It's been a long time since I dealt with buses and everything. I learned about them in college but that was it. I'm especially thankful you pointed out the gigabit LAN information. This board has built-in dual ethernet ports, but one says ASF. Those built-in ethernet ports would be running on the PCI bus, right? I'm thinking, based on what you said, it might make sense to disable the onboard LAN and use a PCI-X gigabit ethernet card....
        There's also SATA connectors, but a group of them says SAS. They're the ones that have the solid state hooked up to them. SAS is Serial Attached SCSI and is compatible with SATA or SCSI drives, right? I'm wondering if I'd see any performance gain if I bought some SAS solid state drives instead of using just normal SATA solid state drives...
          Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
          The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
          The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
          10-23-2024, 03:26 AM
        • vbogoev
          Read eMMC chip using SD card reader
          by vbogoev
          I found several sources where guys successfully read eMMC chip using a SD card reader. I was interested to try it, just to practice micro soldering, but for some reason I am unable to read the chip. The chip is known working one (desoldered from an old working device) model Samsung KLM8G1WE4A-A001. The card reader is Transcend USB 3.0. So basically I've connected everything as it is described in the schematic, but the sd card reader didn't even start to blink. I am not sure what I am missing, so I'll appreciate some help... ...
          07-08-2023, 10:47 AM
        • Technomancer
          Nintendo 2DS SD Card Reader issue. Problem on the clock line?
          by Technomancer
          I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
          Here is what I have done so far:
          -Tried SD card in another 2DS and on PC, works great.
          -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
          -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
          06-07-2022, 09:01 PM
          Apple MacBook Pro A1212 820-2060 USB Audio Card Reader Power Boardview
          Apple MacBook Pro A1212 820-2060 USB Audio Card Reader Power Boardview...
          10-27-2024, 07:21 AM
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
