Asus F5RL problem
  • Jane
    • Aug 2010
    • 189
    Asus F5RL problem
    If I plug in the notebook into mains ,and battery is inserted, the notebook
    does not start.
    If I remove the battery then Asus F5RL starts.
    Battery is good, also notebook was tested with different batteries.The same problem if I use a different battery.
    Does anyone repair a such problem?Where can be a problem?
    Thank you for reply.
  • dhenion
    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
    by dhenion
    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
    The original board was:
    ASUS X510UNR REV 3.0 A
    The replacement board is:
    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
    01-30-2024, 01:45 PM
  • ahmarzo
    Acer TMX314-51 laptop battery problem
    by ahmarzo
    I have acer laptop tmx314-51 with part no 6050A3020501.
    The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
    But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
    I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
    The schematic is not available...
    04-11-2025, 09:14 AM
  • bustacaps
    ASUS X455L Battery not detected problem.
    by bustacaps
    Hello everyone, my problem goes like this... I have Asus X455L laptop. Initial problem was battery not detected so I replaced it with a new battery but still not detected and since it was not detected it was not charging. The battery led(orange) indicator keeps blinking. When pressing power button without plugging the adapter it WON'T turn-on with the new battery installed. But when I plugged the adapter it turned-on immediately(not pressing power button anymore). The laptop has display by the way. Also I noticed the fan spinning fast(I can hear its sound).
    The troubleshooting I've...
    06-13-2022, 09:31 PM
  • cope
    Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
    by cope
    I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
    Some history:
    Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
    As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
    Now, with a new battery the system will start up and run off...
    05-13-2024, 09:40 AM
  • NConstantinou
    LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
    by NConstantinou
    Dear all,
    i have the above laptop which had a problem with battery. i replaced it with a compatible one..
    the laptop DOES NOT POWER ON..
    with it old battery it does power on.
    i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
    when i shutdown the laptop does not power on.
    does anyone have any solution!
    when is not power on the usb c voltage tester shows 5v 1.3A
    when i disconnect battery and power on and then connect battery the tester...
    12-10-2024, 04:52 AM
