You can install Linux on a 2.5" IDE HD with a USB-to-IDE external 2.5" HD case or adapter, on any machine with a USB socket and a well-supported USB host chipset (just about any Intel, Via, ATI, ... chipset). The only tricky part is making it bootable, which requires fooling around with the grub.conf or lilo.conf and making it point to /dev/sda or similar.
It may still barf while booting on the target machine, because of LBA/geometry problems - just play around with different grub/lilo options.
FC3/FC4 will run fine even on PII/266, provided you use a lightweight window manager like XFCE.
Edit: That's a mobile coppermine or tualatin, probably ULV (ultra-low voltage). In combination with a 440MX, it's a bulletproof platform.
Well, I really was thinking of just using Windows 2000 on it.
The fact that the onboard video only has 8Mb of memory really limits down my Linux choices and I already have a system running Linux.
I only need the thing to run Steam so I can play Half-Life, Counter strike and run a few other things like Word.
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate.
Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook.
Manual shows Audio Out and MIC jack under cap on left side near power switch.
Says: "Connects a Hi-Fi set."
Spec section says:
Integrated into Crystal codec CS4299, 20-bit stereo digital-to-analog
and 18-bit stereo analog-to-digital converter, Windows Sound System
compatibility and full-duplex capability.
10.4-inch TFT XVGA LCD, resolution up to 1024x768, 18-bit color.
8 MB (built-in on VGA chip).
Integrated into ATI RAGE Mobility-M1, MotionComp capability,
hardware aid for DVD playback and dual view support.
VGA port via optional docking station.
Ahhhhh HA HA HA HA
The most evil sound card I have ever experienced. No drivers for it from windows, and good luck finding working drivers! Same thing was integraded into my old p3 vectra vl600 board, eventually got the original hp vectra vl600 disk from hp.
And you could put XP on that. I have it running on my Dell inspiron 3500 with a p2/333 and 256mb ram, 4gb hard drive. Remember, xp will adjust how much ram it uses to how much you have, that laptop has 256, so xp uses about 120 when it runs. I can see why that picture said not to touch that one spot, thats where the processor is and it has no cooling device what so ever.
I would go with XP if I just had at least 16Mb of video ram. 8Mb I think would just be a tad too little.
Manufactures site I linked to up above has sound drivers for it for NT4, W98, W2k, and XP.
They should work for you too if it's the same sound chip.
By mfr specs it should be a 700Mhz on 100Mhz FSB.
Your chipset supports 4 banks of memory.
A 256Mb Low Density Module is 2 bank.
A SO-DIMM slot can handle 4 bank.
If they completed the wiring from slot to chipset for the other banks (even though they were only expecting 2 bank) then it might handle a 4 bank module even though it wasn't advertised.
At the time the laptop was built 512Mb SO-DIMM Modules didn't actually exist much (if at all) in the open market and so wouldn't be mentioned in the old documentation.
It's not unusual for them to build something with contingencies for expected new technologies but to not mention it in the documentation if the technology isn't officially released yet by the time the machine is sold.
If you can find a 4-bank 512Mb module (!I don't even know if they exist in SO-DIMM!) and that wiring is in place the chipset might handle it like two 256Mb modules in to side-by-side slots.
I say this because:
Was a long time ago so I don't remember all the specifics but I worked on a 2 RAM slot laptop where the docs said 256Mb/slot max and I got a single 512Mb to work as long as second slot was left open.
*If* you slot is fully wired,,, a 4 bank module 512Mb module *should* work.
No warranty expressed or implied. -
Hmmm, that might be worth testing.
Now the thing would be I would have to find a compatible 512Mb SO-DIMM that if I found out does not work, I can return and just live with a 256.
If you want to try 512Mb it would likely have to be 4 bank.
If 4 bank even exists it will be rare and hard to find.
256Mb pieces are fairly common and cheap on eBay anymore.
Make sure it's 16 chips on the module and you should be okay.
