VPN issue, transfers data constantly
  • Maxxarcade
    • Jul 2006
    • 973
    I noticed that lately when I connect to my home network from my work computer with VPN, it will start transferring information from my home network, bogging down my task at hand. If I just let it go for a couple hours, the received data amount will be around 600-800MB.
    It never seemed to do this until a couple months ago, but it is really annoying.
    I also disabled the "use default gateway on remote network" option, so I know it's not that.
    Any idea what it could be receiving? It does this every time I use it now, so it's not something left over from a previous session. And it does this when it is simply connected, even with no programs running.
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    🛠 Original Issue
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ugamazing
    by ugamazing
    12-17-2024, 07:05 PM
  • harp
    simple win network with optimization issue
    by harp
    simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
    06-23-2025, 11:01 AM
  • ahmarzo
    Acer laptop battery draining issue
    by ahmarzo
    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
    08-02-2025, 06:39 AM
  • howardc64
    Samsung UN55JU650DF network/streaming problem
    by howardc64
    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
    07-09-2025, 12:44 PM
