Sony DRU-800A
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Sony DRU-800A
    My good old Sony burner is acting up. It will not read some of the data DVD's that were make by it now. The other "junk" drive will read them just fine. As I am a heavy smoker could the optics in the drive just need a cleaning? If this be the case would a Q-tip and some alchohol do the trick?
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Sony DRU-800A
    its worth a shot, but usually the nicotine does damage and builds crud in places that you cant clean.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Re: Sony DRU-800A
      Thanks Topcat. I do see your point. The thing had a bad price tag when new but not now. I think a better replacement drive can be had for $50 today. Maybe I should pour a cold "Bud" in it. Its tired and just wants a cold one now Mate!
      Mark Twain
      John Paul Jones
      Rod Serling
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        Re: Sony DRU-800A
        Try cleaning the lens with a cotton swab (yeah, Q-tip) and a lot of isopropyl alcohol. Household alcohol is better than nothing but it can be slightly more aggressive than isopropyl, depending on what kind of additives are into.
        Zandrax
        Have an happy life.
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Re: Sony DRU-800A
          Come on now....I can't trash my grain on this thing...LOL
          Mark Twain
          John Paul Jones
          Rod Serling
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Re: Sony DRU-800A
            No, No, now I do maybe understand.....Maybe....Do you mean to use the rub-rub crap or my American Corn....????
            Mark Twain
            John Paul Jones
            Rod Serling
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: Sony DRU-800A
              shame on you for suggesting alcohol abuse!
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                Re: Sony DRU-800A
                @ KC8: I'm a teetotaller, I never drink alcoholic beverages nor I suggest to do.
                I didn't realize "household alcohol" doesn't mean cleaner with denatured ethanol used at home but alcoholism at home, so I apologize for my mistake.
                I thought household was a good translation for italian adjective casalingo, a 360 degrees word referring to house-made (house-made cooking such as house-baken bread) or house-related objects (e.g. kitchen furnitures, dishes, pots, decorations) and people working at home. I was wrong.
                So, my advice is to clean the dvd lens with a q-tip and isopropyl alcohol: other cleaners may work but YMMV.
                Zandrax
                Have an happy life.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  Re: Sony DRU-800A
                  alcohol abuse is the wasting of perfectly good booze on junk electronics.
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    Re: Sony DRU-800A
                    Here! Here! Well put Kc8adu. What brand of beer do you like best? I'll check my local store and see if they stoch it. They carry brands from all over the world.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • zandrax
                      Hit and miss
                      • Dec 2007
                      • 1157
                      • Italy
                      Re: Sony DRU-800A
                      KC8, you silly boy
                      Zandrax
                      Have an happy life.
                      • Carlos#2003%
                        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                        by Carlos#2003%
                        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                        02-15-2024, 07:52 PM
                      • dkneyle
                        Sony KDL-46HX850 Can't upgrade/update firmware
                        by dkneyle
                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                        09-25-2024, 10:44 PM
                        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 05:27 AM
                        Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                        This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                        09-06-2024, 05:30 AM
                        Sony VAIO VGN-SR29VN/S S Specification for Upgrade or Repair
                        This specification for the Sony VAIO VGN-SR29VN/S can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-SR29VN/S boardview and VGN-SR29VN/S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
