Hi all...
I have this Abit I-45C motherboard that do weird things... well, just like old car, if it wasn't warm up, it doesn't runs right. On cold boot, it won't give any display until I turn off the board and turn it back on. Now everything runs like normal, including passing memtest. After that, when I was attempting to install windows 7 on it, after windows finish loading the files, it would freeze at the windows 7 logo animation (before the logo even start appearing). After few attempt, it still freeze at the same place. Then I decided to boot with Ubuntu, amazingly everything runs fine. Then I reattempt to install windows 7 again, and now it is able to went pass windows boot animation and the installation was completed successfully. I had done prime95 for 1 hr+ and it doesn't shows any error. After resting the board for few hour, same thing happened again when I attempt to start it, freeze again before windows loading animation would appear. After running into safe mode and a restart it was able to boot into windows just fine.
What could be the problem ? is it the cap or some BGA things (the 945 chipset does run quite hot).
In the picture :
- Mark in red, Sanyo WG
- Mark in yellow, Rubycon MBZ
- Mark in blue, Rubycon YXG
-On the processor secondary section there seems to be some mix between "fake" and real solid caps.
Thanks everyone
In the picture :
Thanks everyone
