Obligatory backup server question
  • junktv
    • Nov 2010
    • 3065
    Re: Obligatory backup server question
    Am i the only one that uses thumbs, big external drives and random small drives for back up?
    Is there a way to sort multiples by file not names? I have tons of multiples and sometimes I change the names.
    Did i see deathstars mentioned? Then again it wasn't maxtor. All drives fail.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      I have too much data for thumb drives and USB HDD's are slow. eSATA isn't terrible, but when you have a system with hot swap trays cabled to a controller that supports hot swapping, it makes backup a breeze!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • junktv
        • Nov 2010
        • 3065
        I have esata port and on board. No hot swaps and a tower i wanted that did had issues and was discontinued after selling many for $300+. Could add something to the 4 open 5" slots but why. Most my old drives are IDE.
        • Hondaman
          • Sep 2008
          • 1058
          Is the Asrock brand any good? I heard they make Asrock boards on the same line as the Asus stuff, and I have mixed results with Asus. The 4 disk capacity of the AM1H-ITX looks good, and I can put it in any attractive cube (AM1 passive cooler $10, still in stock). Asrock is supposed to be the Asus company's more "value priced" line. But they still have to have good quality or nobody would buy Asrock, right?
          I have no experience with Asrock, I'd like to hear from anyone who does.
          • mariushm
            • May 2011
            • 3799
            No, it's good brand.
            Right when it started, Asrock was for some time the offshoot of Asus that could afford to design some budget motherboards and some wackier designs that Asus didn't want to risk their brand with (like having AGP AND PCI Express on a motherboard, or hacking chipsets to allow both SDR and DDR1 or DDR1 AND DDR2 on chipsets that officially didn't support this) or having motherboards with CPU slots in which you could plug a special card with cpu and memory that overrides the older onboard cpu, for example to upgrade from Socket 754 to Socket 939
            They also used some chipsets on a few motherboards that were considered "budget" or "value" like the SiS or Uli , which were popular in Asia but rarer in US and Europe.
            After a while, they also got into normal and higher end motherboards and they're quite decent and solid, nowadays they actually make some motherboards that are better than what Asus or Gigabyte releases.
            I personally wouldn't hesitate to buy one, it would be my second choice after Gigabyte (i just like the color themes more) on the same level with Asus, and the 3rd place would be MSI.
            later edit: Just a note, it's written in the manual as well. If you power the board from a 19v laptop adapter, the motherboard has to produce 12v for the fans and the hard drives besides the 5v it has to produce anyway for the USB ports.
            There's a power connector for hard drives right by the sata ports and you get a cable in the box but the cable only has two sata power connectors and the manual says only two drives should be powered from the motherboard.
            Of course, you can use a sata to several sata power connectors adapter/extension cable but I'm not sure how much current can the dc-dc converter on the motherboard provide. It may be able to power 4 hard drives or it may not, they only guarantee 2.
            Modern hard drives don't use as much power on 12v as older drives did, for example my 4TB HGST NAS drive says 12 @ 0.85A on the label so maximum 10 watts or so from 12v. Lower rpm drives like the 5400 - 5900 rpm drives use less, around 12v @ 0.55A. There should be some margin to allow more than 2 drives , especially if you won't use fans (they use about 12v @ 0.15-0.25A)
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              #26
              My latest mobo is from Asrock, it's my first one:
              https://www.badcaps.net/forum/showpo...0&postcount=21
              I'm very impressed by the brand and their novel solutions.
              • Spork Schivago
                • Mar 2012
                • 4734
                • United States of America
                #27
                I have a customer who has a much older Asrock motherboard, socket 775. It could have been when they were first starting out but it's a much cheaper board. They used electrolytics that looked like polymers in the VRM circuit. The electrolytics were under the heatsink and I think the heat destroyed them.
                However, I have heard rumors that they really picked up the ball and now make some pretty good boards. I don't have any experience with the newer boards, just this older one. I want to say it has 3-phases, which isn't very good. You're probably asking about the newer models though, not the older ones. If they really did improve a lot, I'm glad to see that. I'm glad to see them take the money they made off the earlier cheaper designs and invest it into making better boards. I think that says a lot about a company.
                -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
                • Hondaman
                  • Sep 2008
                  • 1058
                  It looks like MicroCenter has a $40 "instant bundle discount" taken off at the cash register. Just buy an AMD chip (in my case the 5350) and any compatible motherboard, and get $40 off the total price. This offer might be good until supplies run out. Perhaps AMD is helping MicroCenter get rid of some older chips.
                  I'll be going to Cincinnati on business in a few days. Anyone else want to take advantage of this? MicroCenter also has the Fractal Design Node 304 at a good price. It looks like I'll be building another computer!
                    New project for a Lipo4 based battery pack for a battery backup that I found an enclosure from Battery Hookup
                    Right now Battery Hookup has these e-bike battery packs that are used but I am going to remove them and test them and see how good they are and maybe resell or reused them for another project this is for another day
                    When I get the rack mounted enclosure that I mentioned in another post I will see how well they fit in the enclosure and how much room I will have left
                    https://batteryhookup.com/products/3...ttery-with-bms
                    These battery packs are a little bit hard to get out of the enclosure because they were a little bit glue...
                    09-15-2024, 12:17 PM
                  • Hondaman
                    File server with PLEX?
                    by Hondaman
                    Down through the years I have tried to have more convenient storage and backup. Recently, I have used a USB hard drive enclosure plugged into the back of my WRT-AC1200 router. But when I put photos on that drive, my local Win7 machine grinds to a halt. It takes a long time for thumbnail images to show up in Win7 File Manager, because I may have hundreds of photos in any directory I want to view. So I need to put the photos on my local Win7 machine. But I am running out of space.
                    Is the router giving the thumbnails from the USB drive enclosure to the Win7 machine...
                    05-19-2023, 12:27 AM
                  • omega
                    Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                    by omega
                    Hello all,
                    as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                    Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                    02-09-2024, 03:34 PM
                    HP EliteBook 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure Notebook 800 Specification for Upgrade or Repair
                    This specification for the HP EliteBook 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure boardview and 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                    09-06-2024, 07:50 PM
