Outlook express gone corrupt "there was an error opening this message"
  • bohdancapek
    • Nov 2015
    • Slovakia
    I am repairing a winxp pc on which Outlook express has gone corrupted. When i first try to open an email it complains that it can't find a .DBX file???? Which has nothing to do with OE and after this on every attempt to open an email or address book it says "there was an error opening this message".
    Tried to create a new identity but as soon as I do this OE shuts down and won't open until reboot. Can still receive emails.
    Tried XP repair but when finished it wanted to activate windows before letting me login which I clicked OK to however all I get is a blank desktop background. So went back and reloaded backup image which I created before started repairs and ran sfc /scannow which did not solve the problem. I am trying to avoid a complete reinstall.
    Any ideas please?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Outlook express gone corrupt "there was an error opening this message"
    http://download.cnet.com/DBX-Viewer-...-75996568.html
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      that is a software problem with OE and nothing to do with the os. reinstalling windows will NOT fix the problem.
      this software problem with OE is a missing or corrupted .DBX file which is a database file that OE uses to store/save all the email for a specific identity. u can find the .DBX files store folder in documents and settings\user name\local settings\application data\identities\{12345-6789-ABCD-EFGH}\microsoft\outlook express. the folder is hidden so make sure u enable show hidden and system files in windows explorer folder options.
      did the user accidentally delete those dbx files by accident? those files store all the emails. dont del them! u might also want to check for a failing hard drive that could have caused the file/folder to become corrupted. also, how many emails does the user have in his inbox, sent items, drafts etc.? if he had a ton of emails, its possible the database file became too big and OE cant handle it anymore so it throws up all sorts of errors.
      • nstevens
        • Dec 2015
        • 9
        Before trying a third party tool, start with the basics. You could have run system restore and return from the last time it was working fine. Or you could also try creating a new admin user or do a clean boot first on the original user. Also, the previous comment from ChaosLegionnaire is possible. An important file could have been deleted or corrupted which is critical.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          here is a tip. If this is your personal email (instead of like a clients or another users)...I suggest you try thunderbird. Import stuff from OE, if you're on imap your messages should stay. I've used thunderbird for over 5 years with ZERO problems
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Which only works if OE works; tbird is dependent on M$ during the initial import...
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • CapLeaker
              ISP blocking emails now?
              by CapLeaker
              Got something new. Recently I got trouble with receiving emails and syncing OneNote. Nothing else. I still can stream 24x7, VOIP, have full speed internet, but in the world cannot receive any emails nor sync OneNote. Take the computer somewhere else to a different internet location and no problems at all. Points to the router, right? NOPE! Hooked up my computer directly to the modem (which is in bridge mode) and have the same problems! Put all the network shit back together, start my VPN provider app, choose the closed VPN server to me and all the problems are gone! Is...
              05-05-2024, 06:16 AM
            • Marian Stocki
              Request corrupt bios repair HP 15-bs100
              by Marian Stocki
              Hi Forum
              Serial: CND80340DV
              Model: 15-bs159TU
              Product ID: 3PP41PA#ABG
              Seeking help have a bricked machine after bios update,
              Can restored a clean bin file but is missing variable information like dmi info, serial & tpm etc (boots into manufacture mode unlocked)
              Think the corrupt bios build is 74 build not sure
              Merging a corrupt bios, hex info is beyond my skills
              Can someone help ✌
              thanks
              Marian...
              03-25-2025, 12:13 AM
            • bandess
              Help to repair dell latitude 5401 corrupt bios
              by bandess
              please help to repair this corrupt bios . computer turn on but no display and fan keep spinning :
              dell latitude 5401 bios corrupt.rar
              MODEL : DELL LATITUDE 5401
              CPU : INTEL i5 9generation
              service tag(s/n) : 3x0jzw2...
              01-22-2024, 05:21 AM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • marc_ytos
              Corrupt BIOS ZX6900
              by marc_ytos
              Corrupt BIOS ZX6900
              Greetings, can you help me repair my BIOS? My computer is a Gateway ZX6900, serial number PWGAF0200901703C186900. The motherboard is da0el5mb6e0. If anyone has a good copy or can repair mine, I would greatly appreciate it.​...
              09-10-2025, 01:52 PM
