Ex-Brother-in-Laws infected PC and possible trouble
  • Spork Schivago
    replied
    Re: Ex-Brother-in-Laws infected PC and possible trouble
    Originally posted by diif
    With hundreds if not thousands of domains registered daily for nefarious purposes using a host file is pretty much a waste of time, sure it will stop some bit definately not all. Far better to follow the advice of security professionals and secure your browser and stay fully patched and updated.
    Mayware tends to communicates with a server somewhere, means the criminals behind it can push other software out to "their" computers. Whilst you might be able to find that maybe but I doubt you'll be able to find who is controlling it.
    It will be interesting to see if its real or fake crypto malware.
    There was some Malware that a person was exploring. He ran it in a virtual machine and watched the traffic from the virtual machine's NIC to the main PC (having the main PC disconnected from the network). He noticed it was trying to connect to an IRC server and then post an IP address and some other info, maybe usernames or something to a channel. Using a sniffer, he was able to grab the username and password to the channel. He logged in and said something to the one user there. I don't remember what it was. Something like this is the FBI, we're tracking your IP address, do not disconnect (or maybe something totally different). Anyway, the kid thought it was one of his friends messing around with him and when he realized it wasn't, the channel and the guy was gone! I thought that was kinda cool.
  • Spork Schivago
    replied
    Originally posted by stj
    disable flash
    disable java bytecode
    if your using windows and they still have it after the IE5 incidents - disable active-x etc.
    I want to say I got a white letter from Java saying that they actually recommend not installing it on PCs unless absolutely necessary and then only enabling it when it needs to be used, then disabling it right after. Seems with every security fix they where coming out with, they'd find or it'd create a bunch more vulnerabilities. So many devices use Java, just not PCs. A good example is Blu-Ray players. I believe a lot of them are rootable because of some Java exploit. I don't know if they just reverse the byte code to source and find a vulnerability in the code or if they are actually exploiting Java itself.
  • Spork Schivago
    replied
    Yeah, hostfiles don't really provide the security that they used to. In Linux, there's distros you can use to setup a PC as a firewall and I've seen software that inspects in the packets for known attacks. Perhaps the software also searches the incoming packets for known malware / viruses. You know, block the shit before it hits the local client rather than at the actually client. I'm sure Windows has a similar feature.
  • diif
    replied
    No script, Ghostery, an ad blocker and click to run flash. And i wouldn't use IE.
    And don't be an admin, be a user.
    replied
    disable flash
  • diif
    replied
    replied
    you or them can get a real or more-real i.p. just by using a UDP ping.
    dont underestimate the number of ways you can both manipulate and work around the routing.
  • Spork Schivago
    replied
    Wouldn't they still need a real IP address in order to receive any information from the infected PC back to their servers? When I say real IP address, I mean to include proxy addresses as well. I know you can spoof your IP address, inject custom packets into the network, etc, but without a real IP address, data could never be returned to the sender, correct? It'd be kinda pointless, being one-way-only. Less you where just trying to get in and then had a dropper or something install software that connects back to a real IP, IRC server, etc. Right?
  • Spork Schivago
    replied
    Originally posted by kaboom
    It's your baby now, hope you like trips to hell. If all his files have been encrypted by the malware, you can't even copy them elsewhere! Well, you can, but w/o the decrypt keys, they may as well be empty.
    They're gonna be all set up and hardened long before they start scamming/pushing, so even if you think you've found an "in," the IP could be spoofed/proxied for all you know.
    Here's the deal: That shit got on there thru some third party script/banner/whatever, that merely used the system as whitespace to "advertise" their numbah. As typical with social engineering, they prey on the stimulus-response. He called the number, probably gave them a code that tied the event back to them; a means for them to "customize" the crap he was "convinced" to download. Sheepishly, he took it; what is this, discount week at jiffy lube?
    Now, by his own actions, he's in over his head.
    I hope this sinks in for anyone else reading: Use a hosts file!
    Coming up on 2016, it's just plain STUPID not to!
    For anyone foolish enough not to run a hosts file, you kill the power at the first sign of the time-delayed droppers! Then, wipe cache/temp/etc. Like any of that needs repeating...
    Wouldn't be surprised. That thing downloaded could be just that! Sort of how microshit does P2P on any computer to help "update" (infect) others, and "spread the love."
    I believe I'm familiar with the scam he fell victim too. I've seen it on maybe three or four customers PCs and I know a couple computer suave people who had friends / acquaintances who also fell victim. Typically, there's two variants, perhaps ran by the same scam artists. The first one, they call you saying you have a virus and need you to go to a website to remove it. Generally, they claim to be Microsoft.
    The second one, the one that my ex-Brother-in-Law fell for, you go to a website, a pop-up appears, it looks like a blue-screen of death. It doesn't look like a pop-up, although it is. If you simply close the browser using CTRL-ALT-DEL or maybe ALT-F4 or just shut it down and restart, you're fine. The window gives you a number to call, claiming it's a Microsoft number and they'll fix it for free. When you call, they get your e-mail address, phone number and address. Then they instruct you on how to go to a website. You go there, download some trojan, and when you run it, they connect to your PC. They lock you out of everything, including the registry. At this point, they say in order to fix it, they need something like 200$. I knew a person who gave them credit card number, social security number, address, banking info, etc. Everything they asked for to "prove" his identity.
    My ex-Brother-in-Law was smart enough to shut it down when they connected to his PC. I told him to bring it in. I doubt any files are encrypted. Albeit there are viruses that can and do encrypt your file system, the few variants that I've dealt with, with this virus, weren't that sophisticated.
    Generally, when ever I come across any infected PC, I simply hook the hard drive up to my Linux box, copy the data off, saved passwords, bookmarks, etc and just format, reinstall. I've found once your PC is infected, even if you have an AV or program like Anti-Malware Bytes, there's really no way to be certain there isn't something lurking behind. Rootkits seem to be extremely hard to remove. I've tried, just for fun, to remove one. Got one removed once but could never get internet back on the machine. No matter what I did, the IP stack was gone. Had to format and reinstall.
    One last thing, I believe once he downloaded what they told him too and when he installed it, they actually go through your PC. Probably using some sort of script, to grab saved passwords, etc. I really hate people like that, that take advantage of other people. Thought it'd be fun to just try and mess with them a little.
  • Spork Schivago
    replied
    they will most likely be using aproxy - probably some haxored pc running windows.
    I agree, they probably will be running some sort of proxy. However, perhaps they own the proxy or if I could get into the proxy, I could look through the logs and find their real IP addresses...
  • kaboom
    replied
    Originally posted by Spork Schivago
    My ex-Brother-in-Law got infected with some sort of ransomware. He's freaking out. Said his PC was beeping and had him call some number, everything was locked up. He called the number, installed the software they told him to install, and then when someone connected to PC, asking for personal info, he shut down the PC. When he restarts, he can't do anything. I'm familiar with the ransomware.
    I had some questions though. Instead of just removing the malware / formatting the PC / reinstalling, whatever, if I could monitor the network traffic, using something like Wireshark, and grab an IP address, and then trace that IP address to a country, assuming they're not connecting via a proxy or something, how much trouble could I get into if I tried hacking into their network?
    There's scanning tools like Nessus that make scanning for vulnerabilities fairly simple and then there's tools, like Metasploit, that make exploiting those vulnerabilities fairly simple. If they're in a country where we don't have diplomatic relations, could I still get in trouble? Or if I where to go through a proxy with a country that we didn't have diplomatic relations with, to hide my real IP, and then tried getting into their network, could I get in trouble?
    Thanks.
    replied
  • Ex-Brother-in-Laws infected PC and possible trouble
    Thanks.
  • f-bone
    Having trouble with Fujitsu D2703-S BUP bios
    by f-bone
    Hi guys,
    I am having trouble finding a way to create a 512kb bin file from a fujitsu motherboard .BUP file.. I renamed it to zip but there are a few files in the I do not know how to combine to a .bin file.
    Please help.
    BR,
    george...
    03-15-2024, 05:20 AM
  • Thefixinator
    Having trouble getting Flexbv to work to view openboarddata files
    by Thefixinator
    Hey guys, I'm feeling like a noob trying to get flexbv to work to be able to download and view a particular board view of a mac mini 2018. Ive tried to read how to use the open board data but it's appearing to be a little confusing on how to actually look up a particular boardview. I'm using the free version to get my feet wet with the software. Ive checked to make sure under the program preferences the openboarddata.org is in the right spot which appeared to be there by default but im not able to open up and board preference to search for a specific board view. I'm probably confused on how it...
    06-18-2025, 11:51 PM
  • FreakyMex
    Trouble to identify part (Lunii screen) for replacement
    by FreakyMex
    Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
    I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
    02-17-2025, 01:16 AM
  • yihuilin
    HP 15-dy0013dx doesn't Power On, Power LED Bilinking, needs help for trouble shooting
    by yihuilin
    Hello Every Genuis
    I have a laptop from my friend, model is "HP 15-dy0013dx" , Logic Board model is DA00P5MB6D0 REV MODEL: 0P5
    this Laptop come with a BIOS Warning issue, the Keyboard CAPS LED Blinking 3 times slow, 2 times fast , don't remember exactly, someting like this, has a Meaning , also Fan will run
    but I googled, people says this Meaning EC have a issue to read BIOS, so I use CHA314A programmer to read and write (wrote the same content file read from BIOS), after I flashed the BIOS, the CAPS LED doesn't blink anymore
    02-08-2025, 08:27 AM
  • valvashon
    LG 55UH6150- trouble powering up, then half lit screen (pictures!)
    by valvashon
    The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
    Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
    11-24-2024, 12:08 PM
