HP Elite Pavilion 2 short beeps 1 long beep, new GPU doesn't change
  • withalligators
    • Jun 2013
    • 267
    Another cool dumpster find. HP Pavilion Elite with 1366 socket, i7 920, 12 GB Ram, GTX 260, 460W PSU. Upon power up gives 2 short and 1 long beep. Figured that was the GPU. Changed it for 2 known working GPUs and got the same result. Tried with different configs of RAM, same result except with no RAM and got a different beep code much sooner. There was a little 4 lane modem card in the top x16 PCIe slot that was getting absurdly hot so I pulled and saw the main chip had popped. Still though, no difference. I tried the GPUs in both slots, to no different effect. Any ideas? PCIe slots dead?
    Cheers
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: HP Elite Pavilion 2 short beeps 1 long beep, new GPU doesn't change
    Likely the RAM. Sorry. Reminds me of my quirky ROG RAM slots on my Asus Maximus II Gene motherboard. (Only one side of each slot has a lever and you must push in the RAM stick on the lever-less side first.)
    And it can take many tries to get it in right!
    That happened when the Maximus II Gene got a RAM upgrade from 5 GB to 8 GB.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • withalligators
      • Jun 2013
      • 267
      I tried the heck out of the RAM. Many different physical configs. Plus the timing is such that it sounds like it's getting past the initial RAM check and onto something else (like initiating video).
      • withalligators
        • Jun 2013
        • 267
        Ok, so apparently these MBs are absolute crap. But I got it going. Turns out the GPU was bad, the PSU was no good (spun up but couldn't initialize?) and the RAM was indeed poorly seated. After tons of trial and error, it's running. I was shocked when I saw the BIOS screen the first time.
        Really annoying fun fact: They have 2 PCIe x 16 slots spaced for SLI/CF but the board doesn't support it.
          • 31294
          what happens if you try?
          • withalligators
            • Jun 2013
            • 267
            Good question, I don't know. I only read up online.
            Just found out something else annoying: The GTX260 is fine. It just won't initialize in the HP. For kicks I pulled an HD 7870 out of another machine to try and it won't work either. I don't have any other 6/8 pin GPUs to try, but I'm guessing this POS for some reason won't read a GPU that is externally powered? I tried 2 other slot powered GPUs, both AMD and Nvidia, and they worked fine.
            Shoot me.
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3266
              • Singapore
              lol looks like the board doesnt support high-end or high powered gpus or sumthing... so much for the system being called "elite". typical of oem pcs.
              just for kicks since this site is called badcaps, what caps does the board have around the pci-e slot area?
              • withalligators
                • Jun 2013
                • 267
                It's not that simple. It shipped with the damn 260 in it. So, something's up. I'll get back to you with those caps manana.
                • withalligators
                  • Jun 2013
                  • 267
                  Matsushita caps on each PCIe slot. so that's something. Also, pulled the PSU and tried it in another rig, works fine. So, pretty safe to say the motherboard is crap?
                    • 31294
                    Matsushita actually written on them???
                    because that's panasonics old (very old) label.
                    • withalligators
                      • Jun 2013
                      • 267
                      They've got the rounded square with the M inside. Black with gold just like pannies.
                        • 31294
                        what else is on them?
                          master hoarder
                          • May 2008
                          • 12175
                          Weird issue. I don't suppose there are any current shunts to detect what type of video card is being ran (i.e. whether or not it is externally powered). Perhaps post a picture of the motherboard?
                          HP usually uses fairly popular brands for their motherboards (though, mostly the cheaper ones), like ECS and ASUS (and sometimes Intel, too). If we see a pictures, we might be able to figure out the motherboard brand and closest model to see what that problem is.
                          Also, always keep a spare PCI graphics card in your drawer . Also handy if you flash the wrong firmware on a (expensive) graphics card and need to re-flash it again .
                          • withalligators
                            • Jun 2013
                            • 267
                            Ooh, I'm an idiot, and never listed the motherboard model. It's an IPTMTB-TK motherboard made by Pegatron. Apparently there is a retail version by ASUS with SLI support but the BIOSes aren't cross flashable.
                            Also, I have like 10 PCIe cards at any given time. Most are total crap though. I even have a handful of AGP cards, who knows why.
                              • 31294
                              i'm thinking those caps may be FJ, those dont always last!
                              • withalligators
                                • Jun 2013
                                • 267
                                They are indeed FJS. So, I breadboarded the MB, to play with it, and now it's up to it's old tricks. No posting with any card in there at all. I think I'm done.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  Have you tried a video card in the PCI-E 4x slot yet? (the one that is cut)
                                  Are you trying the motherboard with multiple sticks of RAM? Perhaps keep trying with only one stick of RAM to rule out bad slots.
                                  Also, is the board really bent under the CPU socket? I know many modern stock coolers tend to bend the crap out of motherboards. I always have to make ghetto modifications on those. It simply isn't good for the BGA in the socket!
                                  Typical of HP. The boards likely have some hardware differences too (usually stuff like jumpers in place of coils or MOSFETs and missing caps everywhere - all in the name of "cost improvement" .)
                                  Yes, but do you have any PCI (not PCI-E) cards? Those are hardy precisely for situations like this.
                                  If they are decent cards, you might want to keep them. Finding a good AGP card is getting harder and harder these days, so their prices will only go up.
                                  • ChaosLegionnaire
                                    HC Overclocker
                                    • Jul 2012
                                    • 3266
                                    • Singapore
                                    hmm giving up so soon? esp when u're on a site like this? not a wise course of action, i think. the pros here will heckle u to change your mind keke...
                                    anyway, my money is on bad caps around the pci-e slots or maybe the whole mobo. i strongly suspect the psu itself has bad caps not filtering out the ripple so the psu becomes a mobo killer and kills the branded panny FJs. i've had a capxon psu kill branded panny FJs on one of my boards. so that explains why high powered gpus dont work on the board. and now the bad caps have deteriorated so much, it now wont recognise any gpu... so i guess u could say thats why u never ignore bad caps.
                                    this issue also reminds me of a previous thread whereby some of the members here were trying to get discrete video cards working on some headless server boards but due to the mosfet design of the server board, it cant and wasnt meant to support video cards as the power draw was too much. but unlike the server board issue which was mosfet design related, your board's problem may be bad caps instead so its still fixable.
                                    momaka could also be right considering how poorly built some oem boards are. there have been cases of warped boards failing to post but after the warpage is fixed, the board works flawlessly.
                                    therefore, the board u have could be suffering from a combination of factors. but if u feel that this is too much work to fix, thats too bad u feel that way. dont trash it tho! give it away to one of the pros here. i'm sure they dont mind paying for the postage to ship the board to them to fix for kicks.
                                      If the modem chip was getting really hot, it is possible a failure on it damaged the PCI-E driver / main chipset.
                                      I believe PCI-E is low voltage, sub 1V signalling, so for example a latch to 3.3V could easily damage the driver IC.
                                      Just something to think about?
                                        HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-12-2024, 03:44 PM
                                        HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                                        This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                        HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
                                        This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        HP Elite Elite 7200 MT Elite 7200 i5-2400 Specification for Upgrade or Repair
                                        This specification for the HP Elite Elite 7200 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7200 MT boardview and Elite Elite 7200 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
