Fibre Optic Connections
  • shadow
    • Feb 2007
    • 732
    I am new to fibre optic cables and fibre optic networks in general. I have come along a snag. I do not know anything about the multiple core fibre optic cables.
    What is the real difference between say a 4 core Multi-Mode fibre optic cable and a 6 core Multi-Mode fibre optic cable?
    What are the advantages and disadvantages of multiple core fibre optic cables?
    This has really stumped me and I can not find the answer anywhere! I have been searching for a little while now and absolutely nothing came up that would help me out.
    Thanks in advance to all those that reply!
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Re: Fibre Optic Connections
    ooooo...this topic got hit.
    hopefully shadow remembers the info.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • scubacamper
      Sharp Aquos LC-70C6400U Half Screen Dark
      by scubacamper
      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
      05-03-2025, 12:19 PM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
    • Msb1xr
      Have to turn on 77” LG C1 multiple times to get to come on
      by Msb1xr
      Have to turn C1 on and off multiple times for it to fully come on
      Have to run LG C1 on multiple times for it to fully work
      If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
      Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
      10-13-2023, 04:09 PM
    • nicktasios
      Troubleshooting Apple Multiple Scan 17 Display
      by nicktasios
      I recently picked up a Quadra with a Apple Multiple Scan 17 Display. The Quadra was not working, it clearly had corrosion from leaking caps so I replaced them and luckily it chimed and worked properly.
      The next problem to tackle was the screen. Sometimes it turns on and off multiple times before finally turning on, and then it sometimes turns purple. After waiting some time, without doing anything, it regains all colors. Another symptom is that it sometimes seems to momentarily blink.
      Also, not sure if this is related, but sometimes, after experiencing these problems,...
      09-17-2023, 03:51 AM
