Another evidence that Powmax PSUs are utter garbage
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    I'll just leave this video here because I was left speechless.
    https://www.youtube.com/watch?v=nd266kl0rs0
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • AJ847.63e
    Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
    by AJ847.63e
    Hi Folks,
    Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
    I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
    The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
    05-06-2025, 10:37 PM
  • RukyCon
    Modding Two PSUs to Output 12V
    by RukyCon
    Hello again, this might be a bit of a far-fetched question, but is it possible to modify a 36v and a 48v power supplies to output 12v? Both power supplies appear to use the same topology, they both also have a dedicated 12v winding wired to the control chips, meaning that as soon as i change it so the main output is 12v, then the dedicated windings will not be able to output 12v, meaning it will not start up. However, if i were to then take the main output and tie it to where the dedicated 12v output would go, then it should be able to run fine?
    Anyway here is a quick overview of...
    02-22-2021, 01:33 AM
  • mubeen14355
    Gigabit Gtx 980ti garbage display
    by mubeen14355
    Hello please anyone help me out
    I have a Gtx 980ti gigabit graphics card The problem is that without installing drivers display is fine but when I trying to install drivers drivers installation failed and garbage in display appears picture is attached...
    03-04-2022, 12:43 AM
  • mubeen14355
    by mubeen14355
    I have a Gtx 980ti gigabit graphics card The problem is that without installing drivers display is fine but when I trying to install drivers drivers installation failed and garbage in display picture is attached...
    03-04-2022, 12:21 AM
  • SuperJames
    Dell G3 17 3779 Weird power cycling and shutdown/restart issue
    by SuperJames
    This one's a weird one, and still unsolved despite it having gone back to Dell once.
    Specs
    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
    Backstory
    I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
    10-23-2023, 04:09 PM
