XpertVision 6800GS no display
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Yes, I do have its power socket attached to the power supply
    When it's the only graphics card, the motherboard will power up, give single POST OK beep, then who knows what afterwards because there's no display
    If I plug in a PCI card, NVFLASH can detect the 6800GS
    Or I can boot into XP, which detects a new device and asks about a driver
    Given 307.83-desktop-winxp-32bit-international-whql, it digests the driver then asks to reboot
    XP then freezes during startup
    Older versions of the driver produce the same outcome
    Trying Linux from Hiren's Boot CD gives "Kernel panic - not syncing : machine check from unknown source"
    I've tried some different BIOSes from the Net, including one from Palit which is supposed to be XpertVision's parent
    All produced the same outcome
    I'm at a loss what to try next - is it a software or hardware problem ?
    If anyone has one of these boards, working, I'd appreciate a copy of its BIOS - with MVKTECH.NET defunct, BIOS options are limited
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • 31090
    Re: XpertVision 6800GS no display
    did you try it in a different motherboard?
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Tried with multiple motherboards
      • c_hegge
        • Sep 2009
        • 5219
        Bumpgate...
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          I don't know whether this had XpertVision's BIOS flashed when I got it - was in non-working condition
          But, FWIW, here are details shown by NVFLASH -V
          Version : 05.41.02.49.00
          ~CRC32 : 39A62E9C
          OEM String : NVIDIA
          Vendor Name : NVIDIA Corporation
          Device Name(s) : GeForce 6800 GS
          Board ID : 4223
          PCI ID : 10DE-00F6
          Subsystem ID : 0000-0000
          Hierarchy ID : None
          Chip SKU : N/A
          Project : N/A
          CDP : N/A
          Build Date : 10/03/05
          Modification Date : 07/07/06
          Sign-On Message : GeForce 6800 GTS AGP BIOS
            • 31090
            it's not the bios, Linux can run a card without one!
            start checking voltages.
            the eeprom works or you wouldnt have a pci id.
            check the ram supply and any other supply's you can spot.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              Originally posted by c_hegge
              Bumpgate...
              Or Chemi-con KZGs that silently failed. I think I see several KZGs on that card.
              • c_hegge
                • Sep 2009
                • 5219
                As I subtly suggested earlier, it's probably the GPU. It is affected by the bumpgate defect.
                EDIT: Yes, the caps are a possibility too
                  • 31090
                  need to get the cooler off.
                  a lot of AGP cards from NV have an AGP interface ic as well as the gpu (that i assume is pci-e)
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Also, check both VGA and DVI ports for output. I had this issue with bad 7600 GT video cards (due to bad Sacon FZ caps) not output anything on VGA, but did output garbage on DVI.
                    Although, I, too am inclined to think this is a bumpgate issue like c_hegge. In particular, the 6800 GPUs run quite hot. At least my XFX 6800 Xtreme was running close to 60C with stock cooler - and anything above 60C is huge danger zone for the 6, 7, and 8 series cards.
                    And of course, those KZG are no good either.
