HDD error help
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Re: HDD error help
    change HDD soon..... wil not auto heal worr
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • sushilachuthan
      APC UPS error P13
      by sushilachuthan
      one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
      the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
      The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
      We replaced the SCR with new device,, but the device is not power on as expected.
      Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
      09-26-2025, 09:00 AM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • SageHappy
      Lenovo Thinkpad 11e showing "Thermal sensing error" upon powering on.
      by SageHappy
      Hello guys,
      I hope you are all good. One day my Lenovo thinkpad 11e laptop just started displaying "Thermal sensing error" after I switched it on. At first I thought it was an issue to do with a defective thermal sensor in my fan. I replaced the old fan with another used fan but, the problem still persists. From where I bought the fan, they said the fan was working just fine so, my question is how can I rectify this problem. Thank you in advance.
      05-27-2024, 12:35 PM
    • netboy69
      Macbook Pro 15, A1990 2018, showing recovery not dfu, error 9 when restore, HELP
      by netboy69
      Hi to all i have a faulty a1990 from 2018, no liquid damage, died during update, now on configurator i see recovery not dfu, and i get error 9. caps around u7701 show short after removing u7701 and shorted caps still short. can any help....
      02-07-2024, 04:34 PM
