Dell inspiron 531 4gb ram 64 bit OS running very slowly
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Dell inspiron 531 4gb ram 64 bit OS running very slowly
    Thanks c_hegge for clarifying, in my defense i'd only had 3 hours sleep after attending a wake.
    Vivi - Was your Windows install for a legitimate source/disc ?
    • Vivi
      Banned
      • Sep 2014
      • 101
      Of course it was. There wouldn't be any other way to install Windows.
      • Rolin
        • Apr 2007
        • 174
        If you have a dual core AMD CPU and 4GB RAM, then it should not take anywhere near 5 minutes to load. Drivers, etc are not the cause. It's probably a failing hard drive (sectors failing and not easily read) - someone mentioned to test the hard drive, and that's a good place to start.
        Another possible cause on Dell laptops is the charging circuit. They have some sort of sensor pin in the AC adapter and a chip on the motherboard to detect this sensor - if it's faulty several Dell laptop models will drop back on the CPU speed as some sort of protection - some models won't charge the battery either. The way to test this is go into the BIOS and check the battery section - it states if it detects the AC adapter properly - should say 65WATT or 90WATT or something like that. If it states something like "unknown adapter" then this could be your problem.
        • Vivi
          Banned
          • Sep 2014
          • 101
          Did I mention this one has 2 hard drives? One that came with it, and another one added to it. The original hard drive only has 74.4 GB and the second one (which came from an 2006 gateway desktop) has 224 GB. Windows is installed on the original hard drive. Before the new hard drive was placed inside, this problem never occurred.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            http://www.hdtune.com/download.html
            Download free trial of pro version. For each of the two hard drives run benchmark and health tab. Post screenshots.
            definitely sounds like a hard drive problem, either with the drive itself failing or a misconfiguration making it super slow. But will be able to tell with this info...
            • Vivi
              Banned
              • Sep 2014
              • 101
              I never thought hard drives could cause a computer to run slowly! alright I'll try this, but I best not to get no virus!
              I believe I downloaed the right one, if I did, I have No idea how to use it. I'm so lost!
                • 31086
                now do that again with a differend data cable on the drive.
                • Vivi
                  Banned
                  • Sep 2014
                  • 101
                  come again?
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4977
                    • New Zealand
                    #29
                    If you just installed all the Windows updates including any .net updates you will get the .Net optimisation thing running for a good while on startup until it sorts itself out.
                    Is mscorsvw.exe running in the background?
                    -David VanHorn
                    • Vivi
                      Banned
                      • Sep 2014
                      • 101
                      actually, yes! it HAS installed a BUNCH of .net updates! though I don't see mscorsvw.exe running in task manager, but could this actually be the root of the problem??
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4977
                        • New Zealand
                        #31
                        Make sure you have enabled "Show processes from all users" and if it's there, leave the computer running until it finishes - If you keep rebooting it won't finish and it'll keep doing it every time you start up.
                        If it speeds up after that, great.
                        If it's not running or it doesn't speed up when it finishes, then I guess it's something else.
                        -David VanHorn
                        • Vivi
                          Banned
                          • Sep 2014
                          • 101
                          I see it! its there! I believe it finished it. I'm not see it anymore even with show all processes from all users checked, I rebooted the computer, (prayed) then logged on, and surprisingly, it logged me on in like: 12 seconds! really! So, in conclusion: does all Windows Ultimate editions have to go through all those .NET updates? And why did you ask me if
                          diif?
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            QFT, looks like Windows had an ATA error and went to PIO mode!!
                            (less than 10 MB/s, especially when at 4 MB/s or 5 MB/s)
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • Vivi
                              Banned
                              • Sep 2014
                              • 101
                              i think this computer is defective, after turning it on today, it completely froze up and crashed. Then rebooting it, it gives me a CMOS battery failed message after boot up.
                              Guess this computer's useless, should I just burn it?
                              • domas
                                News Hater
                                • May 2013
                                • 323
                                • Denmark
                                #35
                                ask your friend that has some knowledge in troubleshooting to look at it;
                                sorry but as I see you don't have the basic knowledge to do that, so our help will most likely be useless.
                                did you check hard drives health status? there was a tab in hd tune with health. why didn't you post that?
                                cmos battery is very cheap and easy to change.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4977
                                  • New Zealand
                                  #36
                                  Originally posted by Vivi
                                  I see it! its there! I believe it finished it. I'm not see it anymore even with show all processes from all users checked, I rebooted the computer, (prayed) then logged on, and surprisingly, it logged me on in like: 12 seconds! really! So, in conclusion: does all Windows Ultimate editions have to go through all those .NET updates? And why did you ask me if diif?
                                  Whenever you install updates to .Net framework it will usually run the .Net optimisation on next reboot. No way around it unless you don't install the updates but that leaves security risks....
                                  The problem with pirate\downloaded Windows DVD images is that some have viruses in them, and viruses often cause system slowdowns as well.
                                  -David VanHorn
                                  • Vivi
                                    Banned
                                    • Sep 2014
                                    • 101
                                    So you're saying my edition of windows is pirated? That's why this is all happening? If so, what will I do then, I tried
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4977
                                      • New Zealand
                                      #38
                                      No, I have no idea if your Windows is pirate. I'm just saying that is probably why diif asked - pirate versions often contain viruses, which may cause this kind of behaviour. Just another thing to check.
                                      -David VanHorn
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #39
                                        The only time i ever see Windows Ultimate is when it's been pirated.
                                        I was asking if it came from a legitimate soure ie, genuine not fake DVD, from a torrent or a helpful friend.
                                        • RJARRRPCGP
                                          • Jul 2004
                                          • 6304
                                          You can easily get a legit Windows 7 ISO of all editions!
                                          And you don't have to worry about them being corrupted.
                                          Arc A770 16 GB
                                            DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:36 PM
                                            DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:30 PM
                                            09-12-2024, 03:28 PM
                                            DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                            DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
