Asus F3E overheating problem
  • edgars_ab
    • Nov 2014
    • 22
    • Latvija
    I was wondering if someone could help me with this. I have a laptop - ASUS F3e Series, which apparently has some problems with overheating.
    I've cleaned it from the dust, changed the thermal compund (various types), even added a copper shim between heatsink and the gpu (which seems to give a bit better results, but not enough), but it always gets hot to approx 78-80C, when i run a burn-in tests on it.
    The problem is - sometimes it just turns off (no restart, just turns off, with no fans, no lights running). I'm not 100% sure, but i think in these moments it somehow exceeds 80C, maybe even 85C barrier, and turns off because of overheating protection.
    Please give me some ideas, what could cause such a problem, because i'm running out of options, as hell.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Asus F3E overheating problem
    You can use a software such as HWINFO32 to check temperatures.
    This laptop of yours i see uses Intel onboard video. Overheating rarely happens with those. Since yours really does appear to overheat, make sure the fan is running properly. If it is making rattle noises or spins slower than it should (doesn't push much air out), try replacing the fan.
    If the fan is good, replace the heatsink. It doesn't happen too often, but heatpipes do lose pressure sometimes, i've had a couple laptops with this problem. The heatpipe is filled with a gas under pressure to move heat fast, and if some of that leaks out, it will be no longer effective.
    A working TV? How boring!
    • edgars_ab
      • Nov 2014
      • 22
      • Latvija
      Hey, thanks for the info, mate! Fan is working as it should - spins fast, airflow is good, no rattle noises. However didn't knew about that heatpipe thing, so it's actually a valuable tip! The only problem is - where to find a replacement. I took an eye on eBay, but I couldn't find any active listing with this exact heatsink.
      I guess your theory explains why a copper shim gave a bit better results - because of ineffective heatpipes, heat was not traveling away from chips as fast as it should, and with a copper shim I somehow managed to increase the heat dissipation area, so at least it doesn't turn off anymore.
      Laptop is pretty old anyways. I think it has some 5 years or so. In result, i'm not really surprised about why this happened. I will double check that video card model, when i'll get at home.
      Anyways, I have also one more, a bit sick idea - could it be, that sometimes the overheating is caused by a bad circuitry on the motherboard (for example a badly soldered BGA chip, incorrect voltages somewhere on the board), or is it always a heatsink/heatpipe/fan/thermal compound problem?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        It is possible for malfunctioning power circuitry to cause overheating, but that basically never happens. VRMs tend to either work perfectly or not at all.
        • edgars_ab
          • Nov 2014
          • 22
          • Latvija
          Well, it seems coper shim does the job well. Laptop still hasn't turned off by itself since the time I implanted it in
          • lazaro.089
            Asus Zephyrus M16 / GU603ZW problem
            by lazaro.089
            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
            CPU: Core i9-12900H
            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
            08-26-2025, 06:33 PM
          • AtelierRepa
            ASUS X712JA problem
            by AtelierRepa
            I have a problem with the bios, let me explain.
            With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
            I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
            My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
            The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
            06-15-2024, 04:33 AM
          • greg1985
            Asus dabkxmb18b0 rev.b bios problem
            by greg1985
            Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
            I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
            I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
            10-20-2025, 11:34 AM
          • boticario
            problem with asus tuf A17 FA707NUR
            by boticario
            I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
            The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
            After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
            I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
            10-18-2025, 04:37 PM
          • boticario
            by boticario
            10-14-2025, 08:38 PM
