Asus F3E overheating problem
  • edgars_ab
    • Nov 2014
    • 22
    • Latvija
    I was wondering if someone could help me with this. I have a laptop - ASUS F3e Series, which apparently has some problems with overheating.
    I've cleaned it from the dust, changed the thermal compund (various types), even added a copper shim between heatsink and the gpu (which seems to give a bit better results, but not enough), but it always gets hot to approx 78-80C, when i run a burn-in tests on it.
    The problem is - sometimes it just turns off (no restart, just turns off, with no fans, no lights running). I'm not 100% sure, but i think in these moments it somehow exceeds 80C, maybe even 85C barrier, and turns off because of overheating protection.
    Please give me some ideas, what could cause such a problem, because i'm running out of options, as hell.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Asus F3E overheating problem
    You can use a software such as HWINFO32 to check temperatures.
    This laptop of yours i see uses Intel onboard video. Overheating rarely happens with those. Since yours really does appear to overheat, make sure the fan is running properly. If it is making rattle noises or spins slower than it should (doesn't push much air out), try replacing the fan.
    If the fan is good, replace the heatsink. It doesn't happen too often, but heatpipes do lose pressure sometimes, i've had a couple laptops with this problem. The heatpipe is filled with a gas under pressure to move heat fast, and if some of that leaks out, it will be no longer effective.
    A working TV? How boring!
    • edgars_ab
      • Nov 2014
      • 22
      • Latvija
      Hey, thanks for the info, mate! Fan is working as it should - spins fast, airflow is good, no rattle noises. However didn't knew about that heatpipe thing, so it's actually a valuable tip! The only problem is - where to find a replacement. I took an eye on eBay, but I couldn't find any active listing with this exact heatsink.
      I guess your theory explains why a copper shim gave a bit better results - because of ineffective heatpipes, heat was not traveling away from chips as fast as it should, and with a copper shim I somehow managed to increase the heat dissipation area, so at least it doesn't turn off anymore.
      Laptop is pretty old anyways. I think it has some 5 years or so. In result, i'm not really surprised about why this happened. I will double check that video card model, when i'll get at home.
      Anyways, I have also one more, a bit sick idea - could it be, that sometimes the overheating is caused by a bad circuitry on the motherboard (for example a badly soldered BGA chip, incorrect voltages somewhere on the board), or is it always a heatsink/heatpipe/fan/thermal compound problem?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        It is possible for malfunctioning power circuitry to cause overheating, but that basically never happens. VRMs tend to either work perfectly or not at all.
        • edgars_ab
          • Nov 2014
          • 22
          • Latvija
          Well, it seems coper shim does the job well. Laptop still hasn't turned off by itself since the time I implanted it in
          • AtelierRepa
            ASUS X712JA problem
            by AtelierRepa
            I have a problem with the bios, let me explain.
            With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
            I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
            My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
            The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
            06-15-2024, 04:33 AM
          • Dobrowol
            Asus GA402RK keyboard and kb backlight problem
            by Dobrowol
            Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
            04-28-2025, 04:30 PM
            ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
            This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
            09-07-2024, 02:50 AM
            ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
            This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
