Sodimms
  • davmax
    • Dec 2005
    • 899
    Sodimms
    Does anyone know if there is any difference between the SODIMMs used in MACbook and those used in IBM and other laptops?
    They look the same, have same speed specs etc. I suspect that they are the same now that Apple have Intel based computers.
    Can anybody please confirm?
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
  • starfury1
    • May 2006
    • 1256
    Re: Sodimms
    well in the past I would be wary of macs and ram.... (psu and hdd)
    I am "guessing" it would be the same but you are right to ask the question
    as there can be traps few with apples
    I would possibly if you get no response to confirm or deny this , perhaps check memory vender's and see what they have as apple memory listed.
    sorry, I am of no real help on this one
    • davmax
      • Dec 2005
      • 899
      Re: Sodimms
      It is possible that Apple place a special link on their motherboard the connects two or more pins so that only Apple specific modules can can used with Apple computers.
      Nvidia 8500GT 256Mb
      33 way card reader
      Windows XP Pro SP3
      • starfury1
        • May 2006
        • 1256
        Re: Sodimms
        Well I dont know about that Davmax but yeah its something they could do I suppose
        Again not conclusive but they make no mention of apple specific ram modules in these links (or any warnings on pc ram)
        this is what they state
        MacBook Pro (Core 2 Duo): Memory Specifications
        You can use Small-Outline Dual Inline Memory Modules (SO-DIMMS) that meet all of these criteria:
        * PC2-5300
        * unbuffered
        * nonparity
        * 200-pin
        * 667 MHz
        * DDR2 SDRAM
        You can use RAM module sizes of 1 GB or 2GB in the top or bottom slots.
        From some searching around the net
        here's what a I gather;
        same size matched pair is recommended
        (and some mention of this in regard to video speed?)
        seems some are using the original with an extra 1GB stick?
        http://docs.info.apple.com/article.html?artnum=303491
        http://docs.info.apple.com/article.html?artnum=304662
        except this
        DIMMs with any of the following features are not supported in the MacBook Pro (Core 2 Duo) notebooks: registers or buffers, PLLs, ECC, parity, or EDO RAM.
        (sort of what you would expect to stated with ram for pc's)
        This all of course my be model specific and not sure what you got.
        HTH
        Cheers
        • linuxguru
          • Apr 2005
          • 1564
          Re: Sodimms
          I've used some PC100 SDRAM SO-DIMMs that are generic aftermarket Macbook/Powerbook labelled parts dating back to about 2002, to upgrade memory in generic x86 P2/P3 notebooks with a variety of chipsets including i440MX/BX, Cyberblade A/i1, etc., without any difficulty so far. YMMV, but if the speed specs are good enough, there should be no problem.
          • gonzo0815
            • Feb 2006
            • 1600
            Re: Sodimms
            I would suggest to use the Kingston site to identify compatible memory modules.
            Then you can crosscheck, if this modul is compatible with other systems.
            From my experience the Kingston site is very accurate.
            • davmax
              • Dec 2005
              • 899
              Re: Sodimms
              Excellent feedback. Thanks guys.
              For the rcord. I am looking at upgrading a Lenovo 8922 and saw right speed and size memory for Macbook on eBay. A check at Kingston site reveals different memory part numbers so could be a bit of a risk.
              Nvidia 8500GT 256Mb
              33 way card reader
              Windows XP Pro SP3
              • starfury1
                • May 2006
                • 1256
                Re: Sodimms
                yes apple is a worry with its range.
                I do sometimes wonder if companies dont use the apple mac thing as away to pump a bit more money.
                use the same ram stick label it mac on it and ask twice the price case they can.
                I used normal PC SDRAM in the G3 crt imac, so like I said only guessing that they have seen the light (or rather cheaper option) and just use pc stuff
                but I know there is traps.
                The spec just maybe in regards to apples specifications, seems apple boxes can be picky about the ram used so maybe it just meets there specs as laid down.
                so your actually going the other way...use Mac ram in a PC. laptop
                you are right it is a risk and definite answer would be nice on this
                • gonzo0815
                  • Feb 2006
                  • 1600
                  Re: Sodimms
                  The Kingston site is a white list, which does not necessarily mean that any other part would be incompatible.
                  So i usually check the datasheets of the recommended Kinston module, which gives a quick answer, if there are some considerations or not.
                  I do this all the time if i am uncertain, if a particular older notebook or system can handle e.g. a large module or if it needs register ram etc.
                  • a_p3rson
                    Apple Watch Charging Controller Schematics / Boardview - 820-02601
                    by a_p3rson
                    Hi there,
                    I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                    You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                    This daughterboard uses an interesting...
                    04-21-2025, 11:41 PM
                    HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                    09-12-2024, 02:30 PM
                    HP ProBook 430 G7 + Apple AirPods Pro Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G7 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Apple AirPods Pro boardview and 430 G7 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                    09-06-2024, 07:50 PM
                    HP EliteBook 850 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                    This specification for the HP EliteBook 850 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G6 + Apple AirPods Pro boardview and 850 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                    HP EliteBook 840 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                    This specification for the HP EliteBook 840 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Apple AirPods Pro boardview and 840 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
