Just got one of these, you have to see one if you are in the market for a TFT, it has this chrome detail around the base and the silver plastic of the screen fascia. I have never seen a piece of computer equipment looking so good. designed by FA Porsche.
Toucb sensitive power on with a blue led. very very good reproduction of colours in photographs. I am no longer a CRT fanatic. 1280x1024 native resolution gets a bit getting used to but after a day I am ok with it.
It has a PVA matrix panel which gives better colour reproduction and better viewing angles (like 178 degrees) than the TN+ used on many tft monitors. You lose the speed though because it is 25ms rather than the 12-16ms seen on the Samsung 172x which uses the TN+. But i did not see a problem in DVDs or gaming. I am really stoked about this product.
If you are holding on to your CRT you have to see it next to your CRT, it will make your CRT look dull. The only problem is no buttons on this unit. It is all windows software. I did not find problems with this either it is just a matter of changing your method to accommodate. Easier to click than reach for the buttons.
i think i have to work harder because now i want two. my CRT next to it connected to another comp just looks like shit.
http://www.techmati.com/reviews/s173p/index.htm
http://reviews.designtechnica.com/re..._main7508.html
http://www.pcstats.com/articleview.cfm?articleID=1607
http://www.mbreview.com/173p.php
http://www.ugo.com/channels/tech/fea...3p/default.asp
http://www.trustedreviews.com/article.aspx?art=679
http://www.explosivelabs.com/reviews/samsung_172x&173p/
http://www.overclockersclub.com/revi...173p_lcd_2.php
