Validate my build
Re: Validate my build
I will admit I've always preferred Intel for Linux support too. Their Linux drivers are absolutely top notch. Then I saw this with some benchmarks:-
https://www.youtube.com/watch?v=JFqQ...U&noredirect=1
While ranking is higher, FPS is better on i5-4460 in all cases. So I'll probably stick with i5 in the end.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I'm running an AMD FX-8350 here, and it is (as said earlier) extremely fast if you can keep all 8 cores busy. For what I do, I can.
As far as drivers, I have a Radeon HD 7770 video card, which works perfectly fine with the open source "radeon" driver. I think it requires some proprietary firmware blobs, but at least it's not fglrx.Comment
Well, the two builds:
CPU: AMD FX-8350 4.0GHz 8-Core ... £125.00
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ ... £82.00
Memory: Kingston 16GB (2 x 8GB) DDR3-1333 ... £93.97
Power Supply: SeaSonic 650W ATX12V / EPS12V ... £87.99
Total £388.96
vs:
CPU: Intel Core i5-4460 3.2GHz Quad-Core ... £130.94
Motherboard: Gigabyte GA-Z87X-UD4H ATX LGA1150 ... £106.92
Total £419.82
(I ended up changing the PSU, this one is not group regulated and looks better built, for only a little more £)
I'm still leaning Intel-wise, but will think carefully about what I need. A lot of CAD work runs only one or two threads so better single core execution may win it.
I'm still not convinced 1600MHz RAM makes much difference after seeing this:
http://i.imgur.com/V0NiI.jpg
A few % differences, at best...Last edited by tom66; 01-05-2015, 04:49 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Definitely go with the Intel build. I would probably suggest going with a current Z97 board rather than a previous generation Z87 board. Bear in mind that a Z87 board will need a BIOS update in order to work with the i5 4460 (which might be a problem if you don't already have an older CPU like a 4440 to do it with).
EDIT http://www.cpu-world.com/Compare/368...5_i5-4460.html
According to CPU World, the 4460 and FX-8350 are both about the same performance in multi-threaded applications, but the i5 is noticeably faster with single threaded applications.Last edited by c_hegge; 01-05-2015, 07:10 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Yeah, I don't have an older processor. So that would be an issue. Buying one is probably not worth it, unless I got the absolute minimum one, but probably still going to be ~£50. Would a Z97 support it out of the box?Last edited by tom66; 01-05-2015, 05:32 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes. Z97 boards support Haswell refresh CPUs out of the box. I'm pretty sure they will also support Broadwell out of the box too. I would probably suggest something like a GA-Z97X-UD3H if you can get one.Last edited by c_hegge; 01-05-2015, 07:12 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
A stock FX pwns my Q6600 @ 3.3 in video encoding.
A Kentsfield is a power hog, lol. And also, my Kentsfield apparently (or much more likely to) also strangely reports bus errors when I don't have sub-ambient temps @ 367 Mhz FSB.
Despite 1.3 V being nothing for FSB termination voltage on a 65nm...
I read that a Kentsfield @ 3.3 easily consumes 250 W at full load.Last edited by RJARRRPCGP; 01-05-2015, 08:32 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Mid-50s under full load with the Noctua cooler... With the stock cooler, I read reports of 80C+ under load, that's why I splurged on the cooler. $25 coolers are also fine, but it's not right that Intel is including these coolers on $200 CPUs. On Pentiums or even i3 I understand.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
But if the chip was sitting in the mid-50s at full load with a hefty Noctua cooler, it stands to reason that 80-90C would be the result with a 15 or so millimeter thick HS/F.
That machine was going to get a high-end cooler anyways. I had a Clarkdale system come in from the same customer with a pancake cooler, and the stock fan was busted.Comment
I will stick with the stock cooler. I've built a few PCs and always used the stock cooler. I've never overclocked them, but I have used them to play games and never had any issues. If I do encounter issues I'll order a cooler.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok, just keep in mind that these pancake coolers are very much fan-dependent. It's not a big deal. If for some reason there's a problem with the fan, you'll know it, because your chip will throttle the speed down significantly.Comment
That's the same for most coolers. Very few heatsinks can dissipate heat effectively without forced air flow. I had a passive CPU heatsink in my old media PC and it was a massive, 90% copper beast. (It still had cooling via the PSU fan though that was on a thermostat which meant most of the time it did not turn at all, silent PC.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
There's forced air flow and then there's forced air flow. These heatsinks are so thin, they're practically rudimentary in nature. It's more like a heatspreader than a heatsink. Absolute rubbish, and I would not use them on something that gets that hot.Comment
I really wish heatsink manufacturers specified °C/W figures instead of vaguely relying on design or size to sell them. It would make it much easier to shop for heatsinks. Luckily some review websites have started testing for this figure, but it's not exhaustive.
I think AA batteries, etc. should also have mAh/mWh figures on them (for non rechargeables) but then customers might realise that all AA batteries are virtually the same.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
PC built and all works good. In the end I went for an EVGA power supply because I saw a teardown showing all-Chemicon output capacitors. But I peered through the vent and I saw Capxon! Blugrh!!
I'm debating whether or not to send it back. It's got a 5yr warranty which I suppose I could use if the capacitors failed. And it was quite cheap for an 80 PLUS Gold PSU (650W). It's also modular - hard to find one like that around the same price bracket. Decisions, decisions...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
To it's credit, there are some Chemicons on the output. But I can count at least four Capxon which could be output caps. It's a NEX650G1. Internal photo that I saw: http://www.overclock.net/content/type/61/id/1948589/
I don't mind the group regulation and I'm not using more than about 250W in normal use.Last edited by tom66; 01-23-2015, 12:19 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I'd leave it alone, since it's only a 250w draw.
At leased they used proper RTV silicone and not organic glue.Comment
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year boardview and 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 01:30 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
This specification for the HP ProBook 430 G7 + 3 Year NBD Onsite Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + 3 Year NBD Onsite Warranty boardview and 430 G7 + 3 Year NBD Onsite Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-06-2024, 04:00 PM
This specification for the HP ProBook 450 G7 + 3 Year NBD Onsite Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + 3 Year NBD Onsite Warranty boardview and 450 G7 + 3 Year NBD Onsite Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-06-2024, 04:00 PM
- Loading...
