Help identifying old PC104 board
  • fzabkar
    • Mar 2009
    • 772
    Re: Help identifying old PC104 board
    Originally posted by thangzero
    Can I solve this issue if I clear cmos, how to clear?
    https://cdn.badcaps-static.com/pdfs/...f3adcf4f8c.pdf
    Remove the chip and short pin 21 (/RCLR) to a ground pin. There could be jumpers to facilitate this in-circuit.
    The RCLR pin is used to clear (set to logic 1) all the general-purpose RAM, but does not affect the RAM associated with the RTC. To clear the RAM, RCLR must be forced to an input logic 0 during battery-backup mode when VCC is not applied. The RCLR function is designed to be used through a human interface (shorting to ground manually or by a switch) and not to be driven with external buffers.
    • thangzero
      • Apr 2016
      • Việt Nam
      It's excactly same your situation. I think i must change RTC. I also can't enter the bios setup the system. Today the system recognize the HDD. thanks for support.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • ugamazing
        Assistance with identifying resistor value on 820-02918 A2992 board?
        by ugamazing
        Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
        I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
        09-06-2024, 08:33 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
