The 2025 Operating System Thread
    • 31249
    maybe recap the analog section of the drive
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      no evidence pointing whether it's the disks or it's the computer... the disks look a little funky...
      • Agent24
        I see dead caps
        • Oct 2007
        • 5072
        • New Zealand
        #63
        Moldy? Happens a lot to floppies and tapes
        -David VanHorn
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          quite possible. Don't know. Weird that it would damage the mag layer enough to make it unable to be recordable again...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            Also wtf. People say you can clean mold off floppy disks? And be readable once more? Seems a bit unbelievable IMHO.
            • TurcoLoco
              ocoLocruT
              • Mar 2025
              • 66
              Currently, have only one desktop running Windows 10 Pro. Of all the 64-bit Windows flavors, 10 is hands down my favorite but among the 32-bit ones, Windows XP was my fav.
              I am and have always been a Windows user, mainly due to being a gamer.
              I have been goofing around with GNU-Linux almost as long as I have with Windows but for the better part of the last 25 years of using Linux, I used different versions on VMs.
              I think I only installed on an actual computer, and for a very brief time, 5 different versions; eLinux, Suse, LinuxMint, Kali and Zorin during those 25 years and spent probably less than 10 hours total playing around with them all.
              For work, I had to learn just enough to support Mac OS users over the years but I really dislike anything Apple! 😬
              • Agent24
                I see dead caps
                • Oct 2007
                • 5072
                • New Zealand
                #67
                Yes, I've done it before, to recover files off old disks, but I wouldn't trust the disk afterwards, the material will be damaged to some extent by the mold, it's not reliable after that.
                -David VanHorn
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8703
                  The number of floppy disks in the world is going down. I wonder if they'll ever become rare enough to have to make them like they do vacuum tubes... then again floppy emulators are a thing, though vacuum tube emulators are not hot....in more ways than one.
                    • 31249
                    some vac tubes have been replaced with good results.
                    shango did some video's showing them - but they arent cheap
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8703
                      well real vacuum tubes are real vacuum tubes, vacuum tube emulators (i.e. using transistors to fake a vacuum tube so you lose vacuum tube properties) "aren't hot"...
                        • 31249
                        you would be surprised about how well they blend in with the other real valves and work
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          TBH I don't even care about the so-called "tube sound" ... IMHO since semiconductors are more linear, they have less THD and thus better...
                          But making a floppy drive emulator really isn't the same thing, might well just emulate the whole machine...
                            • 31249
                            about "tube sound"
                            i suspect it's mostly down to the other parts like shit caps and drifting resistors.
                            maybe some A'file could build a tube pre-amp using metal film resistors and polypropylene caps to compare to a mosfet design.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8703
                              No there really is something to tube sound, mainly because of how tubes handles saturation. Yes mosfets *should* sound similar when running in active forward mode but it's not linear (though you can add circuitry to linearize it).
                              TBH I think mosfets should be run only in class C/D...
                              But we digress...
                              • spycrosoft899
                                • May 2025
                                • india
                                #75
                                Originally posted by Topcat
                                What OS are you running these days? I am down to 3 Windows workstations and one Windows Server on my LAN, everything that doesn't have a windows-specific need has been moved to Linux. Printing abilities with my large document centers are Linux's kryptonite; the reason for 2 of the Windows machines. The third machine still has Win7 on it, and isn't connected to the outside world. It has tons of software on it I use for diagnostics and updating various hardwares. My main rig is still Win10 Enterprise, so I had to vote Win10 in the poll...but I have overwhelmingly more linux machines than windows now.
                                This poll is for PC's. I don't care about your phone.
                                on my 13 systems i use arch except on my x250 (arch but manjaro) on my 2 dell from 2007 and 2009 i use win 10 since there is no gpu support for the fx 2800m and fx2700m basically tesla architecture in general :p (main machine is a w520) i have arch with cinnamon on it 23gb ram :p
                                • em132
                                  • May 2023
                                  • 27
                                  Welp, THIS is nice!:
                                  Mypal 74.1.1 Portable (yes, PORTABLE!)
