Fan thread
  • Maxxarcade
    • Jul 2006
    • 973
    Fan thread
    Would it be worth some time/effort to create a fan thread? Links to data sheets, general info, performance ratings, and most of all, places to buy them?
    No big deal, but since there have been a few threads floating around about fans, I thought it would be cool to put it all in one place.
    So far the links to various places to buy good fans for cheap have been very helpful to me, and probably many others. It normally costs say, $5 each for a decent 40mm fan when you buy them at the local computer shop. Not good when 10-50 pieces are needed
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • b-slayer
    Asus Strix-G15-G513RM fans don't work
    by b-slayer
    I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
    The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
    (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
    (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
    ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
    09-04-2025, 04:58 AM
  • David Stroe
    AOC CQ27G2U/BK - in need of data sheets
    by David Stroe
    I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
    I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
    Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
    Main Board: 715G9500-M0C-B00-005K
    T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
    If someone could please provide any of these data sheets, it would be awesome....
    05-31-2025, 11:12 AM
  • JayPoorJay
    Hot Water Rad - A Few ECU Fans and a Timer Switch
    by JayPoorJay
    Good Afternoon, Good People.
    I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
    I REALLY would appreciate y'alls help.
    This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
    10-29-2024, 12:54 PM
  • amansr12
    Asus Rog strix G513 keyboard, fans not working, battery not charging, works on ac
    by amansr12
    Hi, I recently open my Asus rog strix g1513 laptop to clean the fans and while disconnecting the battery there was a spark near the connector (c6000) and a capacitor (C60050 ) and the keyboard , fans stopped working and the laptop only works when charger plugged in, otherwise no. I removed the burned capacitor and the nearby caps stopped shorting but the problem didn't go away when I turned the motherboard some capacitors ( c8047 c8048 c8049 c8050 c8051 c8053 - connected to pin 25 and 57 of the u8003(ite252e248a) and c8023 c8024 c8046 connected to pin 24 ) are shorting ,,,,pin 26 is ground...
    11-20-2025, 09:38 AM
