Fan thread
  • Maxxarcade
    • Jul 2006
    • 973
    Fan thread
    Would it be worth some time/effort to create a fan thread? Links to data sheets, general info, performance ratings, and most of all, places to buy them?
    No big deal, but since there have been a few threads floating around about fans, I thought it would be cool to put it all in one place.
    So far the links to various places to buy good fans for cheap have been very helpful to me, and probably many others. It normally costs say, $5 each for a decent 40mm fan when you buy them at the local computer shop. Not good when 10-50 pieces are needed
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • David Stroe
    AOC CQ27G2U/BK - in need of data sheets
    by David Stroe
    I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
    I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
    Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
    Main Board: 715G9500-M0C-B00-005K
    T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
    If someone could please provide any of these data sheets, it would be awesome....
    05-31-2025, 11:12 AM
  • JayPoorJay
    Hot Water Rad - A Few ECU Fans and a Timer Switch
    by JayPoorJay
    Good Afternoon, Good People.
    I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
    I REALLY would appreciate y'alls help.
    This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
    10-29-2024, 12:54 PM
  • Raulnn
    clean hisense inner sheets
    by Raulnn
    Can you clean the internal sheets of a tv? I have a 58-inch TV and I don't know if it's worth cleaning the sheets. I have seen that it has dirt on the sheets and the leds are blown. I don't know if they look good when you clean the sheets. Thanks in advance.
    01-22-2023, 05:19 PM
  • sda sad
    my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
    by sda sad
    Hope this is the right place, someone can help me.
    My laptop started having a really strange problem....
    When I turn it on the fans start working at a crazy rate and with random breaks...
    They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
    And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
    The model of the computer:
    Xiaomi Notebook Pro X 15 OLED (A30)
    04-23-2024, 09:55 AM
