A Card that improves Image/Audio Quality
  • Y-3
    • May 2007
    • 6
    Hi there, im new to this board and is a newbie to modding stuff.
    recently i have come across a mod for the X-Fi xtrememusic soundcard,
    http://www.head-fi.org/forums/showthread.php?t=229350
    a soundcard which i currently have. (i still want to know which Caps is related to the power to the front channel opamp, anyone knows? ^^). then i was looking into interference shielding.
    and i discovered a toy made by a Japanese about 3 years ago, Well i know about this about a year ago, but thought it was just a toy and have no function at all until yesterday. the "NO-PCI" card. which will lower the interference for Analog outputs (TVcards/Soundcards.)
    its proven that it works
    http://homepage2.nifty.com/ugee/mtv2200sx.htm
    here is a problem, the "limited edition" which is better, are sold out. and i would like to buy an ordinary one and upgrade it to the limited edtion specs (or better).
    here is how the special edition looks like:
    Components List:
    C1: Not Used (Ground - Shield)
    C2,C3,C4: 150uF/270uF 16V
    C5: 330uF 6.3V
    C6: 150uF 16V
    C7: 820uF 4V
    C8,C17: 330uF 6.3V
    C13,C9,C10,C14,C12,C15,C16,C11: 0.1uF~0.47uF (non-polar cap)
    Net List:
    Component Side: Side B
    Solder Side: Side A
    C13-,C9-,C2- : B1 (-12V)
    C3+,C4+,C10+ : A2 (+12V)
    C12+,C14+,C5+ : B5,B6,C5,C8 (+5V)
    C15+,C6+ : A10,A16,B19 (+5/+3.3V)
    C16+,C7+ : B36,B41,B43 (+3.3V)
    C8+,C11+,C17+ : B61,B62,A61,A62 (+5V)
    C13+,C9+,C2+,C3-,C4-,C10-,C12-,C14-,C5-,C15-,C6-,C16-,C7-,C8-,C11-,C17- : (0V) B3,B15,B17,B22,B28,B34,B46,B57,A18,A24,A30,A35,A37,A48,A56
    Wima Greenbox 0.1uf.. (green ones)
    Can some kind soul tell me around how much will they cost and where i can get those components online? (would prefer to use OScons caps)
  • Y-3
    • May 2007
    • 6
    Re: A Card that improves Image/Audio Quality
    which series of Oscon should i use?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      why not forget that gimmick and just use oscons at the pci bus supply bypass caps?
      what does that silly thing cost anyway?
      • Y-3
        • May 2007
        • 6
        thanks for ur reply, kc8adu, there are 4 versions which varies from 25-38us.
        can you explain a little on "use oscons at the pci bus supply bypass caps"?
        • gonzo0815
          • Feb 2006
          • 1600
          Look at your particular board, determin wich caps are near the PCi bus and are caring 5v or the some other PCi related voltages.
          Then replace all of those caps with Sany Oscons and you may have improved mor than this card could ever do.
          Appart form this, i think if this card is carefully desinged and does eliminate noise from the data lines too, i think the price is ok.
          But if it does only add some filter caps to the supply, then i thing kc8 suggestion is far bether, as it tackles with the root cause (=lousy bad caps for PCi decoupling, on most boards there are many empty silkscreen spaces in that particular area too) of this problem
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            something is rotten in denmark on that card....
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              stinks of audiophool snakeoil.
              • pentium
                • Mar 2006
                • 2778
                If it was say $1 I would get it for the silkscreening/board etching.
                Find Nedry!
                Check the Vending machines!!
                • tazwegion
                  • Jun 2006
                  • 444
                  I'm curious if the primary reason that these product works (reportedly) is because it shields the audio/video cards much the same as a foam/silverpaper layered mod would
                  Viva LA Retro!
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    It is far to cheap to ever make it to the top of this section.
                    If it would cost about 200$ to 500$ then may be it would make it in on of those various audiophiles guru guides.
                    But i think it is violating some basic rules there: no OFC cooper is mentioned, no silver nor gold plating, no mysterious working principle is mentioned.
                    It is just to real and explainable than any of those gurus would be kind enough to bother with it.
                    So far from any mysteries i think it could be possible, that there could be some sound improvements form it.
                    But sure, i would probably not buy it myself too.
                    • bgavin
                      • Jan 2007
                      • 1355
                      I see JC Whitney has surfaced once again, now doing doing computer parts.
                      200 miles per gallon, no less.
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                      • jimmyboy111
                        TCL Roku 65S421 - Double Side by Side Image
                        by jimmyboy111
                        .. swapped mobos and matched them close as possible .. now this .. two images side by side I am guessing wrong resolution .. everything else is working fine
                        .. unable to get into service mode with new update any help is appreciated
                        https://imgur.com/a/Mzhz0Iw
                        https://imgur.com/a/fxB7wV8
                        07-11-2023, 10:54 PM
                      • Rozp
                        70LE660U dark cloud or black screen with sound.
                        by Rozp
                        Hello Everyone,
                        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                        08-29-2023, 05:25 PM
                        HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                        09-06-2024, 10:56 AM
                        HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                        This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
