Oddball SATA Optical issues
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Recently I put a BD-ROM drive in my main workstation. The drive is a hp bddvdrw ch20l, which also has a model number on the label lge-ch10ls20, which leads me to believe it's a rebadged LG CH10LS20.
    Here's the issues I'm having:
    1. I tried to install CH10LS20 firmware to it... but due to the "special" hp firmware, the installer won't recognize any Ch10LS20 drives as present (not even grayed out). Is there a way to make the LG flasher force-flash the drive (as HP has no updated firmware available). Or should I let the old 2010 (or earlier) stock FW be?
    2. I'm not sure if it's an issue with my mobo (tyan Thunder K8WE s2895) or what, but when I boot up, the drive hangs, flashing the status LED and the POST screen showing some nvidia boot sequence saying "detecting array...". I don't have the N-force professional 2000's raid enabled (it's explicitly disabled in the BIOS).
    No other SATA optical drive of mine has done this on this board; with nothing connected (and the first time I installed the drive) the drive spins up fine. Likewise, if I hold the tray open during POST, the system boots up just fine.
    Otherwise, the drive seems to work... I don't have any BD discs to try in it though.
    Any serious (not "workstations suck") suggestions?
    sigpic
    (Insert witty quote here)
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Oddball SATA Optical issues
    workstations suck...
    Yes, I'm kidding. I don't think they do, and the only reason I posted that is because you told me not to say that.
    On the other hand, I think LG makes most Blu-Ray drives. HPs, of course, and at work a customer wanted an IOMagic BD-RW drive installed. The software on the disc that came with it said IOMagic but had LG logos all over the place. Relevance? Absolutely none. But perhaps this information is helpful. It probably isn't!
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      ...mainly due to past threads turning into that. If the issue is indeed with the Nvidia N-force pro 2000 chip, then so be it (and do say so).. but don't tell me that the issue is that it's a workstation.
      Some more info....
      First, if left to hang, eventually it POSTs and boots up win7. But, the drive still blinks the LED and isn't detected by windows at all. However, I did try warm plugging it (booted with the drive blinking) and upon wakeup, the drive was detected and working. Like wise, as already stated, if the tray is held open during bootup, there is no hang issue and the drive works correctly.
      BTW, here's the hang message:
      sigpic
      • mariushm
        • May 2011
        • 3799
        I think it may have to do with the fact that your SATA controller is probably SATA1 or lacking some sata features like hot plug detection or AHCI or some other weird issue.
        Did you connect the drive onto a separate sata raid card, or into the onboard (chipset provided) sata ports?
        • Agent24
          I see dead caps
          • Oct 2007
          • 4952
          • New Zealand
          If it is an LG CH10LS20 the datasheet says it uses SATA 1.5Gbps so it should probably work even on the oldest SATA1 controllers.
          -David VanHorn
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            looks to me like the system is just taking too long to detect that there is no disk and to move to the next boot device in the order.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              The onboard ports of course. I thought about using a dual port ide to SATA adapter I have but I'd rather not if possible
              Even with it excluded from the boot order, the system would hang.
              sigpic
              • mockingbird
                • Dec 2008
                • 5484
                Open it up and check if it is a Renesas chipset or Panasonic.
                Yes, they can be crossflashed, just drag the flasher into MediaCodeSpeedEdit, and it modifies it so that it doesn't do the check.
                Be careful, you can brick your drive.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  It's a Renesas chip.
                  sigpic
                  • mockingbird
                    • Dec 2008
                    • 5484
                    Here is the flasher:
                    http://sourceforge.net/projects/flas...urrent_stable/
                    Make sure to dump the old firmware before experimenting with the new one.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Checked the dumps against the extract using a hex editor, they're listed as the same model (oddly, CH10NS20) in the first few lines.
                      flashing it now...
                      edit- flash successful. Suck it, HP. Suck it.
                      sigpic
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Re-flashed it with LG's utility, which saw the drive this time... still works great.
                        Also, the other issue (boot hanging) isn't happening either... My guess would be loasy firmware that wasn't an issue in the HP systems this drive was intended for... so HP couldn't be bothered offering an update.
                        Thanks mockingbird for the suggestion.
                        sigpic
                        • danoji
                          • Jul 2021
                          New link as per mockingbird's original find: https://github.com/devilsclaw/flashe...urrent_Release
                          • reformatt
                            Intel iMacs, 3rd party SSD failures and Fusion setups
                            by reformatt
                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                            12-18-2024, 10:34 PM
                          • DynaxSC
                            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                            by DynaxSC
                            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                            The board is generally working now, all PCIe ports are working, Windows installs normally.
                            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                            03-10-2025, 12:27 PM
                          • federalhouse
                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                            by federalhouse
                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                            **Background:**
                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                            **What I've Tried So Far:**
                            1. I accessed
                            08-01-2024, 07:03 PM
                          • cheeky2
                            Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                            by cheeky2
                            I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                            Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                            The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                            Details:...
                            08-17-2023, 04:34 AM
                            HP ProBook 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 600 Specification for Upgrade or Repair
                            This specification for the HP ProBook 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                            09-06-2024, 08:50 AM
