ZIP Drive drivers
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    ZIP Drive drivers
    Hey I was wondering if anyone would know where to find windows drivers/software for a Panasonic JU-811T012 ZIP drive.
    I have some old ZIP disks and was trying to read the data from them.
    I am running Windows Vista and it recognizes that the drive is there but cant read from it.
    I know that the drive is good because I used to use it on another pc until the HDD went bad.
    Any help is appreciated
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    Re: ZIP Drive drivers
    I've never needed a driver to operate a ZIP drive, as long as the interface worked (SCSI or IDE), the drive always worked....but I've always used Iomega....couldn't swear that to be true with a Panasonic....but if the OS sees and is able to access the drive, but its unreadable, the drive is bad or the disk is bad. Zip drives were not known for their durability.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      So chances are that the 15 year old disks are bad?
      canadaboy25
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16955
        If we're taking bets, I'll take that action for sure!!! Thats like asking if a 15yr old floppy is still good....but on that note, I still have some old AOL floppies (yea, they used to mail out their software on floppy disks)...I'd reformat them and use them typically as startup disks or kernel driver disks that are needed during installs for drivers that weren't embedded.
        Team : 49813
        Join in!!
        Team Stats
        • Elysarian
          • Mar 2013
          • 200
          • United Kingdom
          I'm not sure I actually own a drive capable of reading a floppy any more...
          I think I have a few 3.5" disks laying around someplace, probably shareware ones (or maybe re-purposed AOL ones with tape over the write-protect hole).
          Thinking about it, I also had some 8" floppies with IBM system/36 operating system code on them but I think they got thrown out
          When I was at college we had to hand coursework in on 5.25" disks (am I showing my age yet?)
          • canadaboy25
            What is normal?
            • May 2013
            • 509
            Haha I had a tray of 3.5 inch floppies and about 7 of them were bad.
            My first pc was an apple iie so I still have some 5.25 floppies in the basement. Surprisingly all of the ones that I tried still worked.
            The Vista pc has always had trouble with older media because it just crashes when it cant read the drives right away. The only other operational pc with an IDE port that I have is a 1996 Seanix Technologies ASI 9000 running windows 95. Would Windows 95 recognize a drive like that?
            canadaboy25
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16955
              It should. I used a SCSI Zip drive with win95 and NT4 all the time, no drivers were needed. An IDE interface won't need a driver for the zip drive either.
              Team : 49813
              Join in!!
              Team Stats
              • canadaboy25
                What is normal?
                • May 2013
                • 509
                I have used floppies for most of my life and just recently started using them for startup disks and stuff. It took me a fair while to remember how on earth to disable the write protect on them haha.
                canadaboy25
                • canadaboy25
                  What is normal?
                  • May 2013
                  • 509
                  Well I'll go pull it out and see if those disks have any life left in them. (just for laughs)
                  canadaboy25
                  • canadaboy25
                    What is normal?
                    • May 2013
                    • 509
                    Well it read the disk perfectly. There was a readme file so I opened it and it said "This disk was compressed using DriveSpace3, which requires Windows 95."
                    Well now the question is would imgburn run on windows 95 so i could put the files on a cd and copy them to my pc?
                    canadaboy25
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16955
                      Compressing data to conserve disk space....I remember people doing that back when HDD space was at a premium...it always led to recovery messes when the system would crash.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        iomega should still have them online.
                        sigpic
                        (Insert witty quote here)
                        • Elysarian
                          • Mar 2013
                          • 200
                          • United Kingdom
                          might be easier to network the win95 machine to something newer (perhaps with a crossover cable?) and copy the files that way - assuming you could get the computers to talk to each other.
                          setting up an ftp server might work if ms file sharing doesn't.
                          • t.j.
                            • Apr 2010
                            • 383
                            • canada
                            what about right clicken on file an running in compatible made for 95?
                            • cheapie
                              null
                              • Jul 2010
                              • 849
                              I use a null modem cable to connect my old Windows 95 machine to my main (Linux) box. It's incredibly slow (even at 115200 baud) but it works.
                              • Elysarian
                                • Mar 2013
                                • 200
                                • United Kingdom
                                I remember doing that to copy files from one machine to another (business accounts) - IIRC I used XCopy and it took forever (about a gig of files from a 486 running windows 3.1 to a Pentium 133 machine running win95, fastest I could get the serial link to work was 28.8k reliably).
                                Took even longer than it should have thanks to a fellow employee accidentally releasing the bungee cord that was holding the door open which pinged across the room and actually hit the power button on the old PC (it had an AT style PSU with the old-skool proper on/off switch rather than the momentary/hold down for 4 seconds ones that ATX's have)
                                • lti
                                  • May 2011
                                  • 2545
                                  If the old computer has a network card, connecting the two through a switch or Ethernet null modem cable (I don't know what that type of cable is really called) would be the fastest.
                                  I still have a parallel port Zip drive, which does require drivers. Windows doesn't install any automatically, and I never ran the Found New Hardware wizard to see if Windows would install a driver without the disc that came with the drive. I didn't know any of them would have built-in drivers in Windows.
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16955
                                    Win95 should be fine on a LAN..... Unlike modern OS's though, make sure you manually install 'client for microsoft networks', file and print sharing, and TCP/IP, as none of that crap is there by default. Remove all the unneeded crap, like IPX, and so on. You will need the trusty win95 disk if the CAB's aren't on the HDD. After that, put the machine in the same workgroup, and you should be able to access.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
