HP Dx2000 not booting
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4544
    • Italy - Milan
    HI, i have this desktop pc that i got broken for free, i don't wanna to buy a new hardware, the mainboard is not booting, it makes the POST with no errors, it recognizes and test well various DIMMs , usb storage, hds, but it always arrive to the "CMOS setting wrong" message "Press F1 to enter setup" "Press F2 to load default values", i press every key but it remains stuck, also CTRl-ALT-DEL does nothing, keyboard is good, when i press F10 for network booting it does something different, or F9 for Boot menu.. i have toggled the cmos battery for more than 1 day, nothing different, i have tested with oscilloscope the dc-dc converters, no ripple, service manual tells that it has a self test for firmware/bios integrity that propose for a bios rewriting if is bad, but it doesn't, it remains stuck there, what type of problem could be? More a flash bios problem or hardware? i think the first.. but i'm unable to reflash.. On board there is a jumper that says:
    "1-2 Normal, 2-3 Safe, OPEN Recovery" i have tryed all the three with no differencies, in Safe it doesn't powerup, What are theese setting for?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4544
    • Italy - Milan
    Re: HP Dx2000 not booting
    have you ever tried to program a flash of a mainb. with another mainboard? The eprom contains POST code, BIOS and maybe something other, i think the bios comes copied to ram at boot by default so the cpu access the bios to ram (faster), this is why i have booted a mobo many years ago and after detaching the bios chip the mobo still functioned, but i had no success in putting a bios chip from other mobo and program it, don't remember what happened.
    • cheapie
      null
      • Jul 2010
      • 849
      Did you actually change the CMOS battery, or just remove and replace it?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4544
        • Italy - Milan
        i have used a new battery but was a low quality, but i've also booted with a good 3v Lithium batt. with different format adapted, no changhes.
        • Elysarian
          • Mar 2013
          • 200
          Probably a silly question here...
          Are you using a PS2 or USB keyboard here?
          If the latter you may be having issues if legacy support isn't on by default in the BIOS.
          If you have access to a PS2 keyboard (the sort with the round mini-DIN plug) you may have more success with it accepting the keystrokes.
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
            by Vesko356
            08-11-2023, 03:27 AM
          • istvanszasz99
            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
            by istvanszasz99
            Product ID: RZ09-0421
            Motherboard: CH580
            Bios File Size: 32,768 KB
            Dear Forum Readers!
            !!! MY RAZER BLADE...
            Yesterday, 05:52 PM
