HP e vectra
  • barry wilkins
    • Aug 2009
    • 172
    HP e vectra
    I have just had this given to me,the reason I am interested in it is the facts
    1/ it has a comm port
    and
    2/ its got windows 2000 software .
    I have some software that will not work on Vista or W7 and needs a comm port.
    But it does not seem to want to work,it comes on and the cd drive activates ,no display or bleeps ,not sure if the hard drive runs up.
    Has anyone got any advice to help me getting to work.
    thanks
    Barry Wilkins
  • ronnygracias
    Help with freemotion incline trainer with controller comm error
    by ronnygracias
    The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
    11-04-2024, 01:32 PM
  • ktmmotocross
    OLD HP Vectra VL400 - not start, beeps PSU in protected mode
    by ktmmotocross
    Hello.
    Have this OLD HP Vectra VL400 with board mark D9820-60011 that not start. 2 beeps pointing to "PSU in protection mode" which leads me to nothing, because psu is ok and i dont find any short on board and when shorting green wire on ATX connector PSU start. it was replaced by normal psu but it dont have fan to CPU, so CPU was overheating. So where to find fault. board, CPU ? dont have schema or bv so i need help
    11-23-2022, 04:48 AM
  • mscottdoran@gmail.com
    Can anyone identify the classification of this data signal?
    by mscottdoran@gmail.com
    Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
    The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
    The boards are powered by a ground referenced...
    02-08-2025, 11:31 AM
  • double_DD
    HP Thunderbolt dock G2 - "fixing" it so it can work without original HP charger?
    by double_DD
    Hi guys,
    I do hope this is not off-topic.
    I have this mentioned HP dock which is half-defective, as it sometimes work and sometimes not. But that's not my main issue at the moment.
    I don't have any more original HP charger, and I would like to "fix" the dock so I can use it without it. Has anyone tried it, or maybe does someone know how to effectively bypass the "comm" pin of the charger?
    Maybe someone has a schematic that would be useful? There are markings on the board that say P&Q 2019 CM-4 94V-0 E162264, but when I try searching...
    09-10-2024, 05:16 AM
    DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
    This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
    09-06-2024, 06:31 AM
