REBOOTS (NO BSOD, automatic restart disable)
  • Calchaqui
    • Oct 2005
    • 112
    Drives me crazy, Windows Xp SP3 default Directx9, FX5600, runs fine, reboots at 1 second of with 3dmark03, no BSOD, just reboots or PSU go to sleep mode, change PSU, same thing but just reboots (no sleep mode). Question is, can a SOFTWARE/DRIVER problem reboots like that? not freeze/BSOD, 5v line is a bit lower 4.76v-4.85 with BOTH psu
    I LOVE WWW.BADCAPS.NET
  • Sparkey55
    • Jan 2010
    • 1523
    Re: REBOOTS (NO BSOD, automatic restart disable)
    Are you running a mobo that gets cpu voltage from the 5 volt line or a mobo that uses 12 volts to power the cpu? Also the PSU maybe to weak for the GPU causing the restart. You can change how the computer reacts to crashes in the advance settings. Change to diplay error code instead of restarting pc.
    • Sparkey55
      • Jan 2010
      • 1523
      Need to determine if it is a hardware or software problem first. What are you using to read those voltages from? Best use a vom analog or digital taken from a free molex connector.
      • cheapie
        null
        • Jul 2010
        • 849
        Does it reboot when running a Linux LiveCD or some other OS?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          What motherboard model is it?
          Muh-soggy-knee
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            That was going to be my question. Board model? CPU? Cap brands/condition? You left way too many important details out.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • Calchaqui
              • Oct 2005
              • 112
              Sorry guys, it's old hardware so I'm ashame of it. Mobo takes power to VIO and Vcore from 5v line. It's an Asus p2b with a Cumine 1.13Ghz, I've found it's not an AGP problem, Microsoft memory (booteable memtest clone) show same symptons REBOOT or go to sleep mode. Board is full of sanyo and rubycon caps. It always creash at test n4 using cache, disabling cpu cache didnt help, this's the second psu (codegen with 30A on 5v rail)
              • Calchaqui
                • Oct 2005
                • 112
                That's the first thing I do when install WinXp.
                • Sparkey55
                  • Jan 2010
                  • 1523
                  Are you overclocking the memory bus? The P2B is a 100Mhz bus. Also Coppermine CPUs are not supported unless you do the mods for core volts below 2.0V
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Last time this happened to me it was in and AMD AM3+ system and BIOS update fixed it.
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      A bios update will not fix his problem. Without hardware modding running Coppermines on that board will not work properly if at all. He is pushing that board to its limits as far as the OS is concerned and the GPU card.
                      • Calchaqui
                        • Oct 2005
                        • 112
                        Thanks God this guy had the same problem: http://www.tomshardware.com/forum/14...g-test-memtest
                        He found that p2b is very picky about slotket. In particular, my slotket (Soyo SY370 recapped) was rebooting (or putting psu in sleep mode) at test 6 microsoft mem. test using cache. I know nobody will care about this, but perhaps it helps some retro hardware guy. Thanx guys.
                        • Sparkey55
                          • Jan 2010
                          • 1523
                          Glad to see you found that info, will bookmark it. I have some Asus P2B-F and P3B-f, do not know if effected by that problem or not.
                          • Calchaqui
                            • Oct 2005
                            • 112
                            My P2B-F behave so weird, it didnt reboot, it freezed twice per month with the Soyo Slotket. P3B-F was a more cleaner design, almost bug-free. P2B-F has a very weak 5v line, tried 4 psus 30A+ and never go higher than 4.76 at IDLE.
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              Google search for "photoshop bug". The mods should fix the quirkyness of the P2B-F and P3B-F mobos.
                              • Calchaqui
                                • Oct 2005
                                • 112
                                I know that, but unfortunately all links and cache about p2b-f vtt caps for photoshop bug are plain dead, including using TIMEBACKMACHINE site, there is a japanese guy who made custom mods to the p2b-f (i think this guy's a pro), there is also a p3v4x mod (apply to p2b-f) soldering a bridge from 3.3v atx pin to the coil of Vio VRM.
                                http://translate.google.com.ar/trans...en-US:official
                                post it , if you got the p2b-f photoshop bug vtt correction
                                • Sparkey55
                                  • Jan 2010
                                  • 1523
                                  http://www.eecis.udel.edu/~portnoi/asusreworkguide.html
                                  • alexia
                                    Acer A514 52k BSOD..DISABLE RAM onboard
                                    by alexia
                                    please helme....
                                    acer aspire 5 A514 52k, board NB8517_MB_V2.
                                    BLUE SCREEN WHEN INSTALLING WINDOWS.
                                    HOW TO DISABLE ONBOARD RAM.
                                    THANKS....
                                    08-18-2023, 09:38 AM
                                  • shouri
                                    Dell latitude e5490 auto restart
                                    by shouri
                                    Hi guys, can someone help me?
                                    I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                    Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                    At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                    After a few days test, is seems ok.
                                    Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                    12-10-2024, 09:27 PM
                                  • brotank
                                    Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
                                    by brotank
                                    I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
                                    can someone disable onboard ram from my dumped bios, please 🙏
                                    I tried the other bios on this forum with disabled onboard ram, but no success
                                    my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
                                    after that I officially give up 😂
                                    thanks for awesome jobs 😊...
                                    03-16-2025, 12:51 PM
                                  • guyandpit
                                    Asus tuf fa507r BSOD
                                    by guyandpit
                                    Hi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error
                                    05-09-2025, 11:46 PM
                                  • alambrose
                                    LG GRAM random bsod SOLVED
                                    by alambrose
                                    LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
                                    Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
                                    Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
                                    02-12-2023, 06:12 PM
