Help..how do i identify mosfets of similar rating etc
  • firstview
    • May 2013
    • 21
    • India
    I got a friends motherboard and it seems to have 4 mosfets blown up...
    now i know the caps are good cause i changed them a month ago (after fixing my board based on tutorials and help from here..^_^ ).
    it worked fine he said till they had a blackout and then boom the board is gone again. he gave it back to me saying i got a new one and now i really want to fix it...
    problem is i have no idea how to deal with mosfets let alone knowing what to see when u want to buy replacement.
    this is what is written on the burt mosfet nikos p0903bdg (with a code at the bottom just below p0903bdg.
    i reached rs.delivers.in but its having variations on volt and amp etc. and i dont know what to get....
    also i want to test the other mosfets how do i do it with a multimeter...
    Any help is appreciated....
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Help..how do i identify mosfets of similar rating etc
    I don't know...
    Either that power supply dumped primary voltage into the MB, or you had a major "ground potential shift," forcing LOTS of current between two supposed "ground" points. One happened to be the case of that computer..
    Anything else damaged after this power event?
    How are his HDD and optical drive(s)? Are they dead too?
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • firstview
      • May 2013
      • 21
      • India
      Originally posted by kaboom
      I don't know...
      he said his hdd has started clicking on the new board and is planning tosell and buy a new one..And for optical drive he doesn't have any....(says it doesnt last for him cause he ends up raping them....(3years= 3optical drives gone bad)
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        What about other removable devices/cards, such as video card(s), sound card (not including onboard sound), wifi card?
        Anything like that left from the old system now not working with the new board?
        He probably lost all the RAM, too.
        What about the CPU?
        EOL it...
        • firstview
          • May 2013
          • 21
          • India
          What about the CPU?
          nothing of the sort was a simple system asus motherboard with pentium d and hdd with 512 mb ddr1 ram
          no idea about processor or ram cause he said its working.....(atleast thats what the shop tecnician said ...) so he put them on auctioning....
          I guess only the board was hit .....
          • firstview
            • May 2013
            • 21
            • India
            In capacitors there are basically 3-4 main points that u have to see to get a matching one for the motherboard and then the brand name (i prefer rubycon or nichicon). but what do i have to see in mosfets ...i mean there are like 10-15 stuff written on the datasheet......totally confusing .....
            just need a replacement for nikos p0903bdg but i dont know what to look when searching........
            • kylegp
              Lenovo LOQ 15ARP9 - Need to identify mosfets
              by kylegp
              Hi there,
              It seems no schematic or boardview is available for Lenovo LOQ 15ARP9.
              Need to identify these mosfets. Can anyone assist in identification or suggest equivelants?
              Top markings:
              16 UUB
              3A0601
              F1 UUA
              7A1L01...
              11-21-2024, 05:52 PM
            • extrexxx
              Identify mosfets DAG35MMB8C1
              by extrexxx
              Hi I need the reference of this mosfets I upload a photo.
              Green marked?
              Red marked?
              Thx in advance...
              02-09-2023, 12:50 PM
            • BlackScreen_22
              Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
              by BlackScreen_22
              Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
              Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
              I had no problems connecting mosfets and capacitors,...
              08-27-2024, 12:46 PM
            • kotel studios
              Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
              by kotel studios
              Finally got time to fix this board up.
              At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
              Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
              04-22-2025, 05:08 AM
            • tbsmith
              Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
              by tbsmith
              There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
              08-11-2025, 06:15 PM
