Ratdude's main rig V3, maybe
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Ratdude's main rig V3, maybe
    Another facepalm... I was wondering why windows 7 kept b*tching about my USB ports only working at usb1.1... only to find that they really are USB1.1.
    Sorry, but I'm calling epic fail. The thing is new enough to boot USB flash drives... but no usb 2.0? Really? Looks like I really need to grab that usb card then (and also dig out a usb.2.0 powered hub to reach the back).
    sigpic
    (Insert witty quote here)
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      #82
      there are some cards out there with 2.0 ports and a header for the front ports
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I know; I have one on a belkin dual firewire/USB (3 internal USB).
        However, they ain't bootable... and due to my cable routing design things work better if the header cables are kept to the leading edge of the mobo. And it's also a waste of USB ports (my new design is USB heavy).
        sigpic
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5045
          • US
          #84
          why do you need bootable USB ports?
          I have your card ready to be tested, I just need a HD and CD drive, install XP...do probably a 3dmark 2003 test on it or something
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I think the system might be a dud.
            With the ATI card, it works until you install drivers, which after which the sytstem locks up within a few minutes of being logged in. Works fine in safe mode.
            With the Nvidia 6600 card, it works for a few bootups then hangs on the welcome screen after logging in. Works fine in safe mode.
            Linux doesn't work (kernel panic) on the ATI. The nvidia card did the same thing.
            Any suggestions? Or Do I have an Eatx turd?
            sigpic
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              #86
              did you install the AMD AGP 8151 driver?
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                This is the problem I had when using SATA, and why the board was unusable for me.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  What OS?
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    I got it to run under linux and the ati via a fresh dvd (stable, not beta). Nvidia was a no go.
                    Ati has no current linux drivers for that card (at least without rolling back xorg) so it's more ofa proof of concept.
                    Is it possible that my PSU isn't up to par? (it gets very hot).
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      No, there isn't one for windows 7... is there?
                      sigpic
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5045
                        • US
                        #91
                        which is why I must bash you for making rigs with, even though server grade, old boards. No there is no driver for 7
                        I've encountered these kinds of problems before with AGP ports that require a special driver. They're classed to take a PCI bridge driver, but have mainly performance issues without thier own driver. ULI (ali) had a problem with this a few motherboards ago on one of my rigs
                        the AGP controller in most old motherboards is built into the northbridge, here, you have an AGP CHIP, separate from the northbridge. It does not surprise me conflicts might come up, and that AMD abandoned support for it.
                        you wonder if its a power issue. Find any other good PSU, short the ON pins, and plug that fucker into the video card
                        I have a funny feeling this is an AGP issue, and bet if you installed XP and loaded the AGP driver (if you can find it, AMD's site no longer has it), that you could run 3dmark without a hitch
                        with all the $$$ you spent on these rigs, you could of built a decent ivy-bridge system that could kick the ass of those you've tried combined. I see why you would want workstation class boards and heavy duty stuff, but this is the 3rd time something has come up to fuck the project over. You can get a good quality gigabyte board and a celeron 1610 and be done with it already
                        here:
                        http://www.ebay.com/itm/SuperMicro-X...item1c32524621
                        here is a new supermicro board with PCI-E 8x. Take a dremil and cut the ends of the ports off and a 16x card should work in there
                        *sigh*. I *DO* have a dual opteron MSI board, uses s604 heatsinks (and I only have one). But it only has 4 mem slots (DDR 400 ecc reg). I believe its a VIA chipset
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          here:
                          It's a long story that I'm not going to retell. Let's just say I don't want a run of the mill rig. It's something about old server hardware I like.
                          Noted on the AGP. Windows acted like no driver was needed so I figured the driver was already ported to 7 and built in.
                          I'm going to linux it up then... which requires an Nvidia GPU as there are no ATI AGP cards with current xorg support (the last legacy driver focused on speed not compatibility). Still doable.
                          sigpic
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5045
                            • US
                            #93
                            you don't want a 'run of the mill' rig, most people have to pay high prices for that
                            the hardware ID's make it compatible for a PCI bus driver, but the PCI bus driver does not play correctly after drivers are finally installed and it runs using AGP Acceleration
                            what kind of dual processors and ram do you have lying around? you could ebay an LGA 771 with x8 PCI-E and probably get that to work. Asus makes some single-socket LGA1155 Xeon /w PCI-E 16x. Hell I built one of those for my sisters ex. 16GB Sandy bridge xeon, win7 Pro, good Nvidia card
                            If you want windows on this motherboard you're going to have to go XP
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Not doing XP on twin monitors. PITA since you can't click and drag windows around in the same way (you have to unmaximise and remaximise them manually). I'm linuxing it instead, assuming I can get it to quit kernel panicking the live disc. Right now I'm remixing the image with updates... if that doesn't work, I'll have to find some other way...
                              My RAM is DDR1, 400 Speed. CPU wise, I have nothing newer sitting (minus the 1.8ghz Pentium Dual core in the remains of my HTPC).
                              sigpic
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5045
                                • US
                                #95
                                how many sticks do you have?
                                this is what I have
                                http://www.newegg.com/Product/Produc...82E16813130436
                                one MSI heatsink, one missing heatsink, but they take 604 heatsinks
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  this is what I have
                                  8 sticks.
                                  Not interested, 604 heatisnks are a pain (been there done that already). If you had a Tyan thunder K8WE then we'd be talking (but they're $100 on ebay)
                                  I saw this:
                                  http://www.tyan.com/archive/support/html/f_s2885.html
                                  I hope #3 is outdated. If it is, then FML, as I have no Xp x64 COA's.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Ubuntu gnome was a fail. Trying fedora... But I bet it has the same issue. How ironic, a server rig with piss poor linux support. F**k you AMD.
                                    The good news is that I think I found a way to make XP work with twin monitors in the way I'd like (Aero Snap emulation):
                                    http://www.askvg.com/aquasnap-get-wi...-xp-and-vista/
                                    The bad news is that I don't know how much of my stuff I can get to work with it... I may very well have a $200 Stillborn on my hands here.
                                    sigpic
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5045
                                      • US
                                      #98
                                      I can respect the fact you're trying this, but these are old workstation boards at best, ment for XP + AGP Pro card for cad programs. Trying to get them working with new OS's that require a special driver for this "AGP Tunnel" is where your problem comes in
                                      Most motherboards now a day do not even have 16x pci-e slots, only 8x for an extended number of hardware raid controllers. Even at THAT, it might be for naught. I cut a geforce 8400 GS down to 8x and put it in my poweredge 1800 8x slot. Dell logo came up, installed win7, as soon as I loaded the drivers boom, black screen. Put a PCI FX 5200 in there and XP and it was slow as shit, even though it was a 3ghz dual HT xeons with 2GB of ram. Runs fine with ubuntu server. See server boards aren't really focused for desktop usage, for a good reason, its waisted resources. Have a bare integrated video for the linux text console or win server. Notice how server 2008 does not have the 'dx9' requirement that 7 does? THIS is the reason.
                                      I can take a shot of that thread in that 604 heatsink if you want, I know you at one time had 604 heatsinks
                                      if you want a 'different' computer, heres something PCBonez (god rest his soul I assume) taught me. There are these low voltage dual core xeons, and they're cheap
                                      http://www.ebay.com/itm/Intel-Xeon-2...item20c961d88e
                                      the motherboard is priced good as well
                                      http://www.ebay.com/itm/Intel-Dual-X...item35c0ef7e17
                                      you'll need ecc reg ddr2 tho. Again, it only has an 8x slot, and a 16x card might not like it. This is cause its a server board.
                                      supermicro does indeed have a new workstation board listed on its site with an AMD LGA 1944 socket. It is E-ATX, but as you can tell, it has a severe lack of PCI slots and USB ports.
                                      http://www.newegg.com/Product/Produc...irtualParent=1
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        No need, as So far Xp x64 has been a win. Slipstreamed SP2 (equiv of SP3 x32) and I didn't need any audio drivers... everything else I have found drivers for (even my webcam and tv tuner).
                                        sigpic
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          http://valid.canardpc.com/2805965
                                          Runs great. will take pics in a bit.
                                          edit- attached my current temps and the like.
                                          sigpic
                                            ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 10:50 PM
                                            ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 11:05 AM
                                            ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                            This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 07:07 AM
