150W idle? You crazy?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: 150W idle? You crazy?
    That's actually pretty good considering the old hardware, how efficient is the PSU powering it? I tested a setup with a P4 Prescott 3GHz, 1GB RAM, 9800GT, 2 hard drives and it idled at 222W!
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Originally posted by severach
      Any mid range 3D video card draws at least 75W at idle and 120W under load. The cheapies draw 12W-20W so try a cheapie or onboard to see how much the consumption drops.
      Orly?
      http://www.techpowerup.com/reviews/N..._Titan/25.html
      • mariushm
        • May 2011
        • 3799
        Yes, new video cards are quite efficient at idle, any card in the last 2-3 years or so will idle at under 15-20 watts.
        The values just don't make sense, when you do the math and look at what the card can draw from the power supply.
        A 6pin connector is supposed to provide a maximum of 75 watts to a video card, while the pci express slot can give another 60 watts (on 12v, 15w on 3.3v or 1.8v)..
        So to say a card that has no 6 pin connectors uses 75 watts when it can only draw 60 watts from the slot in total is a bit far-fetched.
        That's obvious from the link above, you can see cards like Radeon 6670 using only 50w peak.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          More than roughly 75 W probably requires an external connector.
          Even with PCI-E.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • severach
            • Aug 2007
            • 1055
            In the winter the cost is irrelevant as all heat goes towards heating the dwelling regardless of source. In the summer it's a different story. I had to get the room heat down and i3 based systems did it.
            sig files are for morons
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3264
              • Singapore
              #26
              lol those pentium 4s are power guzzlers esp those 3ghz and faster. my p4c northwood 3.2ghz with 875p chipset, 4 modules of 512mb ddr400, 128mb ati radeon 9800 pro, one 500gb ide hard disk, one dvd burner and 4 fans idles at 137w.
              good thing i decided to stick with the cooler northwood version instead of the presshot. i'd bet the idle power wud be 155w if it was the presshot 3.2ghz... keke~
              • TELVM
                • Oct 2012
                • 547
                • Spain
                #27
                Originally posted by tom66
                ... AMD FX64 dual core 2.8GHz (not overclocked.) ... ... Completely idle, and it is pulling 150W... I was shocked.
                You need this great piece of software: K10Stat
                With K10Stat you can adjust C&Q, freqs and voltages at your will, for overclocking, undervolting, or both.
                To give you an idea of the possibilities, I use K10Stat both to overclock a six-core Phenom II to 4100MHz @ 1.5 volts (320W from the wall grinding Prime95) on full swing, and then to underclock it to 800MHz @ 0.78 volts (just 80W from the wall) at idle.
                K10Stat: A Guide to Increase Power Efficiency
                K10STAT AMD Griffin Processor UnderVolting Guide
                Tuning Cool'n'Quiet voltages using K10STAT
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  #28
                  I dont even want to know what my system draws on idle!! My cpu has a 140w rating! nevermind running 8gb of high end RAm, a hd 6970 plus all my case fans!!
                    I still think 80W is insane.
                    The computer is sitting there, copying data from video memory to the display output, and idling... it should be using a couple of watts, not 150W.
                    Yes, I know a computer is doing a lot more (HDD, fans, background tasks, for a few) but I think the focus on energy efficiency has been lost so it's got to the point of "we don't care, it's your bill."
                    My Raspberry Pi has about a fifth the clock speed and yet uses under a watt in most instances. It can decode full 1080p at about 1.5W power usage, whereas my PC uses 220W to do the same thing.
                    Anyway, I am building a HTPC, I aim for low power during idle, and high (=typical) power during usage. I want to have as much shut or slow down when the system idles. What are the best ways to achieve minimum idle power?
                    The downstairs/basement PC will be a Pi, as it can be configured to stream everything over LAN, including 1080p compressed video, and pipe it straight into the desired video sink (probably a big plasma pulling 200~500x the Pi's power.)
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #30
                      Using 'green' rated hardware, effecient cooling solutions, least amount of system services and processes running when not in use.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        The original FX chips, the FX53, FX55 and FX57 IIRC used a lot of power.
                        When FXs were known for being prohibitively expensive. (2004, 2005 and 2006)
                        Arc A770 16 GB
                          HP Slim Desktop S01-aF0010ns Slim Desktop J4005 Specification for Upgrade or Repair
                          This specification for the HP Slim Desktop S01-aF0010ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0010ns boardview and Slim Desktop S01-aF0010ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-12-2024, 03:28 PM
                          HP Slim Desktop S01-pD0117d Slim Desktop i3-8100 Specification for Upgrade or Repair
                          This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          HP Slim Desktop S01-pD0118d Slim Desktop i3-8100 Specification for Upgrade or Repair
                          This specification for the HP Slim Desktop S01-pD0118d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0118d boardview and Slim Desktop S01-pD0118d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          HP Slim Desktop S01-aF0005na Slim Desktop S01 J5005 Specification for Upgrade or Repair
                          This specification for the HP Slim Desktop S01-aF0005na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0005na boardview and Slim Desktop S01-aF0005na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          HP Slim Desktop S01-pF0127d Slim Desktop i3-9100 Specification for Upgrade or Repair
                          This specification for the HP Slim Desktop S01-pF0127d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pF0127d boardview and Slim Desktop S01-pF0127d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
