Pong
  • pentium
    • Mar 2006
    • 2778
    Pong
    For a while I have left my old vic-20 to collect dust.
    Finally, the other day I found paddles that would work with the system.
    Now I have to find the code to pong.
    That's where the problem arises.
    The closest thing to BASIC is visual basic. oddly enough, a commodore can't use visual (duh!)
    Where can I find a list of the lines of code to create pong on a commodore system?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • flibidy
    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
    by flibidy
    I have here a Magnum IA.100 which belongs to my parents.
    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
    What Ive done........
    01-01-2025, 01:26 PM
  • swofra
    Basic electronic knowledge resources
    by swofra
    Hey all,
    I've got a few XBOX power problems but don't know much about anything concerning electronics troubleshooting outside of replacing caps. Instead of coming on here and wasting people's time being confused when they say check rectifier, transistor, resistor, etc or whatever it may be and then having to ask "what is that?", I wanted to learn and build up a knowledge base first so I'm not completely clueless and can apply the good advice people give without confusing the situation more by not knowing what i am doing.
    Is there a good thread or source, either on this...
    11-07-2023, 06:52 PM
  • JNP-3R
    Information wanted for Venture Line 6 Pac I Pong game
    by JNP-3R
    Hey everybody. I'm curious if any of y'all have experience working on older arcade or pong games. I was recently contacted to help fix up what I believe is a 6 Pac I retrofit board by Venture Line that's integrated into a third party cabinet (Tennistronics?). The unit is old school. All 7400 logic, 555s for timing, and so on. No microprocessors in sight.
    The unit's in surprisingly good condition, but has an issue with the 3rd player paddle. It seems that the paddle will always extend from the bottom of the screen to where it ought to be, it's about normal width if you move it to...
    12-26-2022, 11:09 AM
  • grss1982
    PSU killing components?
    by grss1982
    Hi everyone! Been a while!
    So I have a CM MWE 750 Bronze - V2 PSU powering the following:
    Ryzen 5 3400G
    Gigabyte B450 Auorus Motherboard
    32GB DDR4-3600 (2x16)
    ASUS TUF 1660 TI 6GB DDR6
    1TB NVME
    This was purchased by a friend about 3 years ago for her kid and now it showing signs of instability. The PC had this problem of the screen becoming garbled after it was booted up and idling in Windows. It also sometimes gets a BSOD. So I did some stress test by starting with Prime 95 and noticed that the torture test just fails and stops immediately....
    01-17-2025, 04:12 AM
