WinXP: Howto hide mouse pointer when no mouse connected?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi, I upgraded 2x Fanuc CNC's from NT4 & Win2K to Windows Embedded POSReady 2009 (Basically WinXP SP3, same build number and all)
    They work great and performance is super.
    I just have one question; on the previous NT4 & Win2K installs,
    when I removed the PS/2 mouse & keyboard from the system they would then not show a mouse pointer on system startup anymore.
    But XP does, so there is a mouse pointer in the middle of the screen I can't move now...
    I've done allot of Googling and can't find a solution I really like.
    Examples I have seen: Use a mouse cursor icon with only one pixel or completely invisible.
    Remove the mouse drivers from the system.
    Solutions that are close to what I want:
    nomousy.exe - A small utility designed to hide and/or restrict mouse cursor movement.
    AutoHideMouseCursor 1.42 Automatically hide the mouse cursor
    The first two I dislike because if you add a mouse to the system for maintenance it gets very difficult to use.
    The second two are good, however I'd prefer a solution which does not require a third party program taking up memory
    (these systems only have 128MB RAM) to solve an issue which was not there in Win2K & NT4!
    Do any of our Arcade gurus have some experience with this?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: WinXP: Howto hide mouse pointer when no mouse connected?
    Maybe give this one a try? http://cursor-hider.soft32.com/
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Thanks for the recommendation but it seems to cost money, so then the other two programs are probably better...
      http://www.cursorhider.com/
      I just double checked yesterday and a vanilla Windows XP SP3 has the same behavior, as does Windows 7 SP1
      It is "fixed" in Windows 8 tho
      (I.e. no mouse cursor shown with no mouse connected)
      • mariushm
        • May 2011
        • 3799
        Disable the mouse in Device Manager ?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          mariushm: There is no mouse to disable since I removed it from the system.
          And if I disabled the hidden mouse device it would be a pain to re-enable if I want to connect a mouse for service...
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            I'm using AutoHideMouseCursor v1.51 now.
            This version works well, I reported an issue the program had when explorer.exe was not running as shell.
            The author fixed it surprisingly fast with that version update
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Or, you could hack up a program that would do that automatically, like you want
              Muh-soggy-knee
              • stretch0069
                Screwed Up Super Moderator
                • Oct 2003
                • 2658
                • oooo ess aaaaaaaaa
                not to get off topic, but i thought is was bad to connect/disconnect ps/2 while the pc was powered. mikee confused.....
                "Its all about the boom....."
                Guns kill people like spoons made Rosie O'Donnell fat.
                We now return you to your regularly scheduled drinking.
                "Fear accompanies the possibility of death.....calm shepherds its certainty"
                Originally posted by Topcat
                AWD is just training wheels for RWD.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Connect: usually bad.Some motherboards really don't like hot-unplugging the keyboard ( ?). On the other hand, some laptops will auto-detect and enable anything hot-plugged on PS/2.
                  Disconnect: Try not to do it, but if it happens, no harm, no foul. On systems that won't , a reconnect will usually re-enable the device.
                  sigpic
                  (Insert witty quote here)
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    I'm not hotplugging the PS/2 devices.
                    The system shows the mouse pointer when I coldboot it again with no mouse connected.
                    And yes, it is bad to hotplug PS/2 devices, I especially won't do it on CNC gear costing thousands of dollars
                    I'm not a programmer but AutoHideMouseCursor does what I want.
                    I only wish it was not a requirement, like in NT4, Win2K & Win8...
                    • stretch0069
                      • Oct 2003
                      • 2658
                      thanks gents.....i thought i was crazy......well......
                      • Blargh523
                        • Dec 2012
                        • 46
                        Without using extra software, you can also replace the mouse cursor with a clear cursor file.
                        Control panel -> Mouse -> Pointers
                        Select "Normal Select" then browse to the transparent cursor.
                        Here's one I whipped up:
                        https://dl.dropbox.com/u/36807119/transparent.cur
                        Disclaimer: This can be really annoying to undo.
                        {ETA: I missed the bit about "mouse for maintenance," but I don't have the option to delete this post, so I'll let it stand in hopes it does someone some good}
                          Acer TravelMate P214-52-566U+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                          This specification for the Acer TravelMate P214-52-566U+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-566U+15.6" Bag&Mouse boardview and P214-52-566U+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-06-2024, 07:20 PM
                          Acer TravelMate P215-52-56G5+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                          This specification for the Acer TravelMate P215-52-56G5+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P215-52-56G5+15.6" Bag&Mouse boardview and P215-52-56G5+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          Acer TravelMate P214-52-54NA+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                          This specification for the Acer TravelMate P214-52-54NA+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-54NA+15.6" Bag&Mouse boardview and P214-52-54NA+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          HP EliteBook 840 G6 + Elite Presenter Mouse Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 840 G6 + Elite Presenter Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Elite Presenter Mouse boardview and 840 G6 + Elite Presenter Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 05:00 PM
