Heard a loud pop *APC BKUP XS 1500
  • Mad_Professor
    replied
    Re: Heard a loud pop *APC BKUP XS 1500
    Originally posted by kc8adu
    well at least you found the problem!and found that your ups batts were done before a power problem ocurred that could cost you data.
    maybe a run test every few months?
    4 weeks ago they held a charge and ran on battery for 20 minutes, two days ago they couldn't. I would have to test weekly.
    Anyways electrician, different guy came with a new double pole 60 amp breaker since he wasn't legally allowed to install a 70 due to wire size. All is well, new breaker is running 50x cooler then the last one. The old one was hot when it failed, and ran warm/hot when it operated normally. At least we're ok, I had him check out the subpanel to see if there was any issues, but there wasn't much concern; even with the grounds tied to the neutral bus bar.
  • kc8adu
    replied
  • Mad_Professor
    replied
    not the batteries the whole ups.its the plastic case that stinks.
    Remember when I said it would rear it's ugly head? Well... half my house has no electricity. The double pole 70 amp breaker for the subpanel went bad around 8:30 tonight. It didn't trip, still in the "on" position. One leg failed, the other still provided power. After attempting to do a full reset on the breakers it wouldn't, it felt spongy.
    Called an electrician, he dropped a used 50 amp double pole breaker, turned out that one was bad too, only one leg worked. That's all he had until the morning. So now half the house is dark.
    Most likely the loud pop came from there and eventually failed now.
  • kc8adu
    replied
  • Mad_Professor
    replied
    Sounds like a problem I had with an APC UPS all the way back in late May, 2002:
    All of a sudden, my Phillips 107S CRT monitor wasn't getting power, so IIRC, I unplugged the monitor then plugged in back in.
    IIRC, when I plugged it back in, there was a pop and a blue spark!
    "POP!" right in my ears!
    Then since that, the battery back up outlets are dead!
    The plug contacts were faulty!
    I check the contacts for wear and tear they seem to be alright. Checked the receptacles at the wall, they're ok, they should be, they're brand new only several years old.
    may have been a cell(the bad one?)venting.
    they have little rubber caps retained by a cover.some pop and some squeal/whistle when they vent.
    does yours stink of outgassing plastic?
    i have 3 of these i set up for external batteries and they do well other than they stink.
    No, no smell from the batteries, they are a sealed unit. Can't check them now since I replaced them with new ones today.
    I don't know, whatever it was, it will rear it's ugly head eventually.
  • kc8adu
    replied
  • RJARRRPCGP
    replied
    Originally posted by Mad_Professor
    So I don't know what happen exactly, It's an APC Backup XS 1500.
    Sorry this is going to be long but I think details are the best way to explain a situation.
    I was sitting here at my desktop in my bedroom around 3pm today browsing youtube when I heard a loud pop. My sister was sitting infront of the workstation where the backup was when it happened. She is hearing impaired and still heard it, but was unable to tell me the general direction or location the "pop" came from. I figured it came from outside because of my window was open. As I tried to load another video, I lost my connection to the internet.
    I walk out to the workstation where my server and the modem are located and everything was off. I thought "WTH? the breaker must of tripped." I go back to the panel nothing tripped. Walk back out noticed one of the computers my dad was working on was plugged in on the same circuit and was the last receptacle of the run and had not been interrupted. Also the HP laserjet 6MP was also plugged in on the same plug that battery backup was on which was at the beginning of the run and it had not gone through it's warm up/power on cycle.
    *Confused* I turned on the server and walk back to the panel and push the test button on the breaker *combo AFCI* which tripped. I walk back to the server it was off along with everything else. Looked at the battery backup it says 100% charge but acts as if the battery was dead.
  • Mad_Professor
    replied
    I took the whole backup to the batteries plus and we tried one of their batteries with a dremel drill load and it held it's run time for 2 minutes. SO it was bad batteries.
    Now to figure out what that loud pop was.
  • dmill89
    replied
    I'm not sure about that exact model but I used to have an XS900. It had a 40mm sleeve bearing fan that seized up which caused the switching transistors to overheat and blow out with a loud pop, then It would just continuously beep and do nothing, batteries were fully charged but it wouldn't run on battery or AC. The XS 1500 you have is a newer unit so there may be some design differences. If you have a fan definitely check it. APC tends to cheap out on its consumer grade units so things like low quality caps and fans are very common, the last couple I opened up had either jamicon or CapXon (many only 85C)caps and if they had a fan it was a sleeve bearing.
  • Mad_Professor
    started a topic Heard a loud pop *APC BKUP XS 1500
    This whole time there was no smell or smoke, and my dad has very sensitive nose especially to electrical/electronic burning/burnt smell.
    Something is wrong here. I unplugged the battery backup and dragged it out, check the internal breaker it had not been tripped. Plugged it into a power strip then plug in a 75w lamp to the Battery backup, switched off the power strip and the backup switched over to battery. It went from 710 minutes run time to 0 in 1 minute, then the lamp ran for another 30 seconds as the backup warn me of a low charge then the lamp went out followed by the battery backup.
    This is weird because 3 weeks ago I had issues with the POCO. A fuse kept blowing at the pole and my battery backup worked fine ran 20 minutes with a 300w load then.
    I took apart the battery backup and inspected the board and didn't find anything burnt or blown. Noticed it had capxon caps all over and one cap had a slight bulge on top. Put it back together. Tested batteries *two 12v in series* it said 24v, a fully charged battery would be at 27v if I remember correctly.
    So now I'm left wondering what was the loud pop and why is my battery backup now not working.
    Could it be the batteries? They are about 2 years old now, replaced in 2010. Was that the loud pop? The battery pack seems to be intact, no swelling or physical anomaly.
    Could it be the massive transformer in the backup that went *pop* and is that causing the rapid discharge now?
    I'm curious never had anything like this happen before.
    Any ideas, or what I should be looking for? I checked all devices to the backup they seem to be working fine. I'm confused.
    http://www.apc.com/resource/include/...D&tab=features
    APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
    by sam_sam_sam
    This started a few days ago and does this about every 8 hours
    After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
    The battery backup is about 3 or 4 years old
    Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
    06-02-2024, 02:30 AM
  • Chris_stand
    Clevo PD50PNN won't boot after BIOS Backup
    by Chris_stand
    i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
    At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
    Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
    But the...
    04-28-2023, 03:08 PM
  • DiddiAb
    BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
    by DiddiAb
    Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
    I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
    03-11-2023, 03:15 AM
  • aidanmo
    Philips 43PUS7506/12 - Loud blown out sound
    by aidanmo
    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
    I thought maybe the speakers got damaged, so I replaced them - no dice.
    • Using the internal speakers, it always happens.
    • Using the headphone jack, it never happens.
    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
    02-28-2025, 03:13 PM
    HP EliteDesk 705 G3 EliteDesk 705 PRO 1500 Specification for Upgrade or Repair
    This specification for the HP EliteDesk 705 G3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 705 G3 boardview and EliteDesk 705 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
    09-12-2024, 02:15 PM
