Appalling performance from WD800JD-00LSA0
  • Shocker
    Banned
    • Dec 2011
    • 635
    Okay, tell me if this is just my SATA controller, but seriously???
    Transfer rate:
    Avg.: 3.27MB/s
    O.D.: 3.31MB/s
    I.D.: 3.21MB/s
    Access time:
    18.9ms (-4.2ms for latency = 14.7ms)
    How on EARTH can a single-platter 80GB 7200RPM drive be THIS slow???
    Compared with ST380011A:
    Transfer rate:
    Avg.: 43.8MB/s
    O.D.: 57.3MB/s
    I.D.: 27.8MB/s
    Access time:
    14.9ms (-4.2ms = 10.7ms)
    The Western Digital drive is at least quiet and reliable, but then so is the Seagate.
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Appalling performance from WD800JD-00LSA0
    My guess is that the drive has fallen into PIO mode (which has a limit of 3.4MB/s) instead of DMA, by way of either a damaged drive interface, a damaged cable, something amiss in your OS, or something mechanically wrong otherwise with the WD HDD. I wouldn't mind PIO mode much if it wasn't such a CPU hog (at least, on single core machines, for those still using them), since PIO mode makes high CPU usage a requisite by needing the CPU for every byte sent to the hard disk.
    Personally, I have found (older, 2001-2006, before Seagate and Maxtor's 'merger') Seagates (the Barracudas I've had) far and away the most "reliable" (mechanical) hard disks I've ever used, period, bar none. Possibly even the most "reliable" hard drives I've used. No other drive has so affluently given me as much longevity, speed, and silence, though I must admit I've had good experiences with Hitachi, Samsung (I know, Seagate "merged" with them), IBM (barring their Deathstar fiasco, and I know they became a part of Hitachi, but I mean their drives beforehand), and Western Digital's newer hard drives (especially the Caviar Black drives). I would think any drive (that isn't defective) should last a good while should you treat it well.
    • Shocker
      Banned
      • Dec 2011
      • 635
      It's a SATA drive, by the way.
      The cable doesn't appear to be the problem, as there's only one CRC error reported by S.M.A.R.T.
      AHH!!!!! You were right about PIO mode. I assume it would be PIO 0, as that would account for the ≈3.33MB/s transfer rates. I just started KillDisk to see if there was a further problem and only now did I realise that it would have been a waste of time .
      Still, I don't know why the seeks are so slow .
      • Shocker
        Banned
        • Dec 2011
        • 635
        Ah, better now.
        Avg.: 49.5MB/s
        O.D.: 59.6MB/s
        I.D.: 33.1MB/s
        Only got 0.2ms better access, though.
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          Unless automatic acoustic management is supported and enabled (which would reduce power consumption, seek noise, and therein augment seek time), or unless the drive is just slow in that regard, I'm not sure why the random access time would be low.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Seems right, I have the same crappy harddrive in a system here...
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              I had a 40 GB WD IDE drive of the same model go into PIO mode after getting a bunch of bad sectors. The quick Error Scan in HDTune didn't pick them up, but the normal scan did. There were quite a few red areas all over the drive. Luckily it failed right before the store refurb. warranty expired (30 days), so I got it replaced.
              • Shocker
                Banned
                • Dec 2011
                • 635
                There are even 4500RPM drives that are comparable in some ways to these slugs. I'm not kidding. And if you like, go ahead and compare it with a Bigfoot.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Yea, the disk has become too small for me anyway but it explains why this CentOS6 testserver I have is so damn slow, I will put a Raptor in it's place
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Transfer rate:
                    Avg.: 3.27MB/s
                    O.D.: 3.31MB/s
                    I.D.: 3.21MB/s
                    Looks like the OS is in bleepin' PIO mode!
                    PIO is a dinosaur transfer mode that was popular when 386s and 486s ruled the universe.
                    You must get another cable and try again.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • Shocker
                      Banned
                      • Dec 2011
                      • 635
                      Um, I think someone already figured that out. Read the whole thread. And in case you're wondering, the cause was not having the right SATA drivers installed. Note SATA. A PATA drive would be WD800BB or WD800JB.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Windows could still do that bull when the motherboard is not in AHCI mode.
                        SATA HDDs look exactly like PATA HDDs to Windows when not in AHCI mode.
                        (And I/O errors occur within the ATA interface.)
                        Arc A770 16 GB
                        • Shocker
                          Banned
                          • Dec 2011
                          • 635
                          R-E-A-D T-H-E W-H-O-L-E T-H-R-E-A-D
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            I wasn't born yesterday.
                            Arc A770 16 GB
                            • Shocker
                              Banned
                              • Dec 2011
                              • 635
                              Who was???
                              • Shocker
                                Banned
                                • Dec 2011
                                • 635
                                Okay, so I finally decided to disable AAM and measure again. That made things way better (the drive isn't a Black, but it's >4ms faster than before). And I still can't hear the drive in use. Now I actually think it's just as good as the 7200.7. AAM
                                Forget that I ever created this thread. It's not an awful drive at all.
                                  Microsoft Surface Book Surface Book with Performance Base Hybrid (2-in-1) Specification for Upgrade or Repair
                                  This specification for the Microsoft Surface Book Surface Book with Performance Base Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book with Performance Base boardview and Surface Book with Performance Base schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-06-2024, 08:20 AM
                                • reformatt
                                  Intel iMacs, 3rd party SSD failures and Fusion setups
                                  by reformatt
                                  I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                  As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                  So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                  12-18-2024, 10:34 PM
                                  HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                  This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                  09-12-2024, 02:00 PM
                                  HP ProBook 450 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 450 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Seagate Expansion 1TB boardview and 450 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                  09-06-2024, 08:10 PM
                                  HP ProBook 430 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 430 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Seagate Expansion 1TB boardview and 430 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
