Panasonic Lumix DMC-FX37 Camera Jack
  • SgtRock
    • Feb 2012
    • 175
    Greetings BadCappers:
    --I hope this is not to far off topic. I could not figure where else to post. I have tried all else, to no avail. If anyone knows, you guys do. If the moderator needs to remove, I understand.
    Ahem. I have a new camera I bought to take high resolution photos. See the attached photo of the jacks at the end of the camera. The leftmost jack is for the 5 Volt DC supply.
    I already have a good power supply and just need to find information about this kind of jack and plug, so I can get a plug and solder it on to my power supply, thereby saving $20.
    Thanks for reading.
    Best Regards
    Clear Ether
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Panasonic Lumix DMC-FX37 Camera Jack
    Hi SgtRock.
    Did you find any info up to date about this matter ?
    It is a good idea to PM me also ( an old Friend ).
      DVR camera recorder switching power supply capacitor failure really
      by sam_sam_sam
      These cheap non brand capacitors at it again
      Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
      Well at least I have the cameras back on line I to try the...
      01-22-2022, 06:28 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
      HP EliteBook 830 G6 + Pan/Tilt Home Security Wi-Fi Camera Notebook 800 Specification for Upgrade or Repair
      This specification for the HP EliteBook 830 G6 + Pan/Tilt Home Security Wi-Fi Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Pan/Tilt Home Security Wi-Fi Camera boardview and 830 G6 + Pan/Tilt Home Security Wi-Fi Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
      09-06-2024, 07:50 PM
