Another old Laptop thread
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Well, I was going through stuff at my old hose and found an old laptop... and unlike the others there, which are junk and and have smashed screens, this one actually may be usable!
    what we have here is a gateway solo 2150.
    it has a celeron 433mhz
    it has 96mb of RAM (32 soldered, 64 on a module)
    this poor thing has a plastic cover where the LAN should be... but luckily, 6 months ago I recieved a 3com PCMCIA 10/100 card (the kind with the pop out xjack), which fixes that
    I also was missing half the HDD caddy (must have stolen it for soemthing), but lucky me again, as I had a beat up caddy from a dead HP nc6000, which a was able to cut and file to fit.
    I also had an old 4200RPM 20gb Hitachi travelstar for it...
    I am installing debian testing on it...
    also, I wish I had a 128mb module for it... once I have some 256mb modules for my dad's IBM thinkpad t22, then maybe I can move a module or two...
    I know, , but I gotta have my fun...
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Another old Laptop thread
    one change- I will use debian testing with LXDE... that will run better than gnome 3... I hope...
    sigpic
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I'm pretty sure I have some 256mb PC133 in a box around here, if you're looking.
      Looks like the Solo will only take 1 128mb stick, maximum.
      Ludicrous gibs!
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        umm... the thinkpad t22 is PC100 only. stupid intel chipset. (I have pc133 256mb modules too). If you had Pc100 256mb modules, then that would be helpful.
        what i was saying Is I have a t22 in the house as well with 2 128mb pc100 modules, and it needs a ram upgrade. If I upgraded it, I would then have 2 128mb modules freed up, which I could then take one of and put in the gateway solo this thread is about.
        sigpic
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          128MB isn't enough, even for something like Lubuntu
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            lubuntu?
            the ubuntu part is the issue. bloated.
            debian's core is a lot lighter... we'll give it a try i guess
            sigpic
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              256MB and you're good to go but 128 is a bit low either way You coudl always overclock the CPU :P
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                overclocking will not fix memory size issues.
                I read that on a PII 266mhz with 128mb of ram, lxde ran fast-moderate. I have 96mb. surely it will at least run until I can max it out at 160mb.
                source:
                http://lxde.org/lxde
                sigpic
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  I've got 1 256mb PC100 and one 128mb PC100. I'll poke around at work and see if there's another 256mb PC100 stick there. I might still have one on the discard pile...
                  Ludicrous gibs!
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    even if that is all you end up having, its better than zilch, which is what I currently have.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      time for another ghetto idea...
                      I noticed that the modem is connected as a mini-PCI card...
                      I also happen to have a random atheros b/g/a card and a set of wifi antennas out of a gutted netbook lid.
                      for laughs I booted the laptop with the wifi card in place of the modem... and lscpi from a live cd says that the card was functional.
                      so, would it be epic, stupid, or ghetto to hack into it a set of antennas and install the atheros card?
                      sigpic
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Epic, for sure
                        Stupid, not at all
                        ghetto, maybe, but who cares
                        • dood
                          Deputy dood
                          • Mar 2004
                          • 2462
                          Depending on how far away from the router you're going to be, you may not even need antennas...
                          Ludicrous gibs!
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            well, there is something else to keep in mind...
                            the battery is 100% dead in the unit
                            I also have 4 powerline adapters that I recently modded and fixed.
                            me thinks that using a powerline adapter with it may be a better option. it will not see use outside of my property.
                            sigpic
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              I've tested this several times and have come to the conclusion that you have to be about 6 feet or less to even see it (at low signal strength)
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                my G router is on the upper floor of the house in the attic... not close to much.
                                sigpic
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  lxde runs, but I hate it... trying debian-stable with gnome 2 instead.
                                  sigpic
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    You don't like LXDE?
                                    Ah well to each his own I guess lol!
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      well, it was an unholy mess and trying to do the simplest of tasks was a PITA. heck, i wasn't even able to install a .deb graphically. fail.
                                      sigpic
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        xD Lubuntu works well, so that's my defense :P
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:11 AM
